Thanks again Neomode
Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by neomode View PostI Start to Work on Version 3.2.
Any wishes from the Community for the next Version?
Neomode
Gesendet von meinem GT-I9305 mit Tapatalk 2Overclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by willianpivotto View PostMy mk809iii updated to version 4.4.2 and the audio stopped working, when I install the previous version the audio works normally ... What could have happened? Anyone know how to solve the problem?
The old kernel audio driver defaults to stereo, so in theory the new kernels are better.
I asked neomode if the old audio drivers could be added as options in settings. But I am not sure if it's possible.
Originally posted by neomode View PostOK, I have heard you all and will do my Best :-)
Neomode
Works great with D33 kernels and its quite stable.
A few settings not remaining set after a reboot, location services being stuck off if not turned on on first start.
Missing keyboard.
And a few missing features like daydreams and cheapcast. (think both are still there just controls missing)
Otherwise its stability made stock roms look bad.
Ohh and of course sharks with lasersMk802IV Neomode 1.9a original rom 720p
Help pls...its my first time to flash on an android stick...i hve this device mk809III..i want to try this rom..but im having problems rooting it.....anybody care to give me good instructions..pls..thanks..paper clip not working it doenst recognize device..as i hold it for 3-5 sec.for me to install
Driver...i did how many times..any other ways guys...thanks..am i doing something worng..here is my android stick..
Sent from my GT-I9505 using TapatalkLast edited by warlock09; 06 May 2014, 21:57.
Originally posted by warlock09 View PostHelp pls...its my first time to flash on an android stick...i hve this device mk809III..i want to try this rom..but im having problems rooting it.....anybody care to give me good instructions..pls..thanks..paper clip not working it doenst recognize device..as i hold it for 3-5 sec.for me to install
Where to start.
First its not rooting its flashing a rom.
What OS you doing it on?
Are you pushing the buttion? just sticking a paper clip in does no good unless your hitting it.
Are you pushing the buttion as you plug into the micro usb on the side?Mk802IV Neomode 1.9a original rom 720p
Re: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by warlock09 View PostWindows 7..yes i was pushing it: the reset button with paper clip...5 seconds or more but its not responding..tnx for reply..
You hold the button down as you plug in the usb to the side usb port.
If done correctly it should show device found in flash tool.
At that point you erase idb and then click run after thats done.
Of course all this requires the correct driver to be installed which can be done easily with this tool.
Otherwise windows 7 diver signature verification can block the driver install.
http://www.freak-tab.de/neomode/rkautodriver.zip
In rare cases if the device is stuck you need to use the stock roms and flasher for that.
With that open and the device plugged into the side usb all these devices tend to show up eventually at which point you can click restore and flash the device.
After that its a simple matter to do as instructed for neo rom and flash that.Mk802IV Neomode 1.9a original rom 720p
Looks like more complicated than rooting..hehe...i have rooted how many android phones i got ...anyways..tnx very much for help..appreciated..i will give a try tomorrow again..sleeping time..working early ..tomorrow...i will keep you informed on my progress.tnx..
Originally posted by warlock09 View PostLooks like more complicated than rooting..hehe...i have rooted how many android phones i got ...anyways..tnx very much for help..appreciated..i will give a try tomorrow again..sleeping time..working early ..tomorrow...i will keep you informed on my progress.tnx..
Once you got the windows machince setup with the driver and you done it once its dead simple after that.
Hitting that stupid little buttion the hardest part.Mk802IV Neomode 1.9a original rom 720p
There are currently 2101 users online. 2 members and 2099 guests.
