Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    Originally posted by quadcom View Post
    Hi!, I have the same tv stick. Now I use the Finless KitKat Rom, everything works except BT. KitKat is more faster than JB, and now with stable release XBMC 13.0 Gotham, works much better.
    Here the instructions to apply KK:
    Also you can try the new 4.1 d33's kernel.
    @alxx and people with the new Wifi try with the respective kernel of d33.
    Good luck!
    PS: @elpetrus yo hablo español asi que cualquier duda avisame
    entonces en español mucho mejor, que kernel de los de d33 es el que tengo que poner? El de los stick o el de los tv box?
    Por cierto, muchísimas gracias
      Hola, el de los tv stick, los otros probalos si queres pero seguro no te va andar la wifi, fijate en el link que te pase, yo actualmente tengo puesto el kernel de yerzu el cual es basado en el de d33.
      Saludos!
        Originally posted by Magnus33 View Post
        Works fine.
        Thanks for testing.
        That's strange, with me it looks fine for about a minute, after that the quality degrades to unwatchable while the stream looks fine on my laptop.
        It's like Youtube is throttling down the quality to compensate for bandwidth, which makes it even stranger as I have a 120 Mbit downstream internet connection (wired), wireless is about 70 Mbit what should be more than adequate for a youtube stream.
        Maybe it's caused by "tweaks" that are set by "pimp my rom" , I'll reflash and try again.
        Thanks again for testing.
        Regards
          Hi again ,
          is there a way to use rkremotecontrol as a voice search mic? Or is there any other way to use my android phone as mic? I really like rkremotecontrol - keyboard "swiping" would be great. And if I understand correctly neomode does not support droid mote uinput.ko? Is there a reason or is it incompatible?
          Thanks so far!
          AD
            Is there 1080P kernel without OC ?
            So far i'm using neomad 1.9a and i'm really happy with it
            Think about moving to KitKat
            thanks!
              thanks!
              Here http://www.freaktab.com/showthread.p...l-(well-most!) are 720p and 1080p kernel for KitKat.
                thank you!
                  Problem on mk802iv
                  I tryid to install neomode 3.1 kk rom. I erased the idb and shows me the counting, for erasing it, till 2132, i thought the count would be till 2048, as i saw flashing a cx-919 stick.
                  Then i flashed the rom with the stock kernel (the same was using the d33`s kernels), when i plug in the power, it appears problems formatting e:externalsd, something hat doesn`t happened to cx-919. With the stock kernel everything was fine. With d33`s kernels version 4.1 only penguins and then blank screen. I tried the 4.0 no gpu no ddr kernel, but same result.
                  Can anyone help about this problem. Can d33 fix the custom kernel tha neomode used in the rom to bypass the lock for the T cpu`s?
                  As an idea, it would be perfect if someone could make a patch to use with any kk or not kernel, for bypassing the T frequncy limitations.Like overclockomatic for overclocking.
                  Thanks all.
                    This? -> [overclockomatic for kk]
                    Or this? -> [oveclockomatic FULL kernel suite]
                    Greetings.
                    MK809III clone (T model) + d33 Kernel v4.1 {OC'ed kernel mod} (1.7Ghz/768/800Mhz) !!!
                      Greetings.
                      Thanks for your answer, i know about overclockomatic, this is for overclocking kernels.
                      I meant a new patch like overclockomatic to make kernels for T cpu to bypass the gpu and ram limitations.
                        They actually bypasses gpu/ram limitations: gpu@798Mhz & ram@800Mhz
                        PS. my device doesn't support ram@800Mhz, so I slowed down a bit to 768Mhz and it runs smooth.
                        Greetings.
                          My mk809 III is very slow lately, do not use it much, but few days back here it is very slow, what can I do?
                            Thanks all.
                            That's all normal behaviour.
                            Power it on, let the recovery do it's thing, now the most important tip: when the screen goes black...wait...
                            After some time it will briefly show a KitKat splash, the screen will go black again...now..you've guessed it...more waiting...
                            Tadaaaa...there's the Android desktop
                            Our kernel guru D33 already bypassed all the locks in his awesome kernel, get it here:
                            Good luck.
                            Regards
                              3188-T with AP6210 (wifi not working)
                              I have 2 of these dongles, both are doing the same thing.
                              I am using the parameter4gb file, and the kernel_t_cpu1704h_gpustock_ddr720.img (doesn't matter which kernel I use all do the same).
                              The unit boots fine, but when I enable the wifi it just sits there and never shows any access points, and if I go away from that page and then go back to wifi settings it shows the wifi as being disabled again.
                              In short wifi isn't working.
                              Any help would be apprecaited.
                              hawkeye
                                AW: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
                                Please open your device and see what Wi-Fi chip you have. Then we can see where it hangs.
                                Neomode
