Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by neomode View PostI Start to Work on Version 3.2.
Any wishes from the Community for the next Version?
Neomode
It also needs to be compatible with D33-kernels v4.0.
Best regards,
FredrikMK809III RK3188-T AP6210 running Neomode 3.1
Support for ESP8089 wifi chip
Neomode
Neomode
- Wifi-Direct: app is native-embedded on this ROM and you can actually connect to it from other devices, but you can't send/receive any kind of data
... SuperBeam app does the job, but not as simple as Wifi-Direct.
- Miracast/WimoRX/WifiDisplay: After tried several apps this feature doesn't respond: screen appears on Settings but it doesn't recognize any device. WifiDisplay app comes embedded in some dongles with 4.2.2 version, also in new 4.4.2 roms (like CR9 dongle). Is WimoRX the same as WifiDisplay?
- RKRemoteControl: I realized touchpad is not crashing on 2.0.3 version, so it works fine.
EDIT: looking for the right version of WifiDisplay, i found this one: [apk link] ...
You can connect your device, BUT it doesn't initialize the mirroring... [check preview]
Is something missing yet?
Greetings.Last edited by wichoxp; 03 May 2014, 22:45.
Originally posted by wichoxp View PostWell, after one-day testing if found some general issues:
Greetings.
How do you make the WifiDisplay apk work? I get "app not installed" message
Originally posted by wichoxp View PostWell, after one-day testing if found some general issues:- Wifi-Direct: app is native-embedded on this ROM and you can actually connect to it from other devices, but you can't send/receive any kind of data
Greetings.
Originally posted by aracy View PostHow do you make the WifiDisplay apk work? I get "app not installed" message
Anyway, if you have install problems check your root is OK or I'll rip my current apk to share again.
Originally posted by ulises1954 View PostWichoxp I also would like to know how you make the WifiDisplay apk to work?...
Greetings.
Hello all,
just flashed on mk802 iv (coming from last stock rom) and I'm really impressed: it's fast, stable and allow me to play 720p and 1080p without problem, while with the stock rom was completely unusable!
I'm a noobie with those devices and I have a question: i wanna try d33 kernel (version 4.1)...how to flash them? With FlashIt! application? RKFlashTool? Need to flash all rom again or only the kernel?
Thanks all for good job (and support!)
The to the right of the kernel click on the tab and browse to whatever kernel you wish to use.
Put the device into flash mode and flash the kernel..no idb erase or anything else is neededMk802IV Neomode 1.9a original rom 720p
There are currently 3478 users online. 1 members and 3477 guests.
