Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
CX-919
CX-919 Stick.
-Android doesn't remember 2 settings after rebooting.
1. Sound Device (Each boot i have to set audio device from Modiotek USB Headset to RK-HDMI-I2S)
2. And it doesn't remember Screen Scale setting. Each boot i have to configure screen scale.
Or can someone give me a hint, where and how i can edit the rom myself, because this two bugs are very annoying. But i would like to use it, because this rom works very well (fast) with my CX-919 Stick.
Originally posted by imaddiced2u View Postthanks,
I'm using windows 7, also MK809III (T model) here and XBMC 13 beta 3.
I recently found that if I add ip's manually by selecting Add network location, it works through SMB.
Still doesn't work when trying to browse the network by selecting Windows network (SMB).
Seems strange that when running a jellybean rom I could browse the network. My other (identical) tv stick, is still running jellybean and I can browse the network on it to select SMB shares.
Adding SMB shares manually is a bit complicated for my wife so I'll continue to look for a fix that will let me browse the network.
Quite common actually since many routers don't and the easy way to fix this is to restart first the router and then the pc you share from just after that and everything should work.
The reason the other device can still connect is because it still retains the connection info that's no longer being correctly handed out.
I use a freenas box to avoid this problem completely and some store bought nas box's also avoid this issue.Mk802IV Neomode 1.9a original rom 720p
As for screenscale mine does remeber it but it took a few times for it to do so and seems to take a min before it kicks in on reboot.Mk802IV Neomode 1.9a original rom 720p
Originally posted by PolloLoco View PostThinking it might be a bad flash, I tried again and still no sound. So I downloaded the ROM again and rrefreshed, but still no sound. Going back to 1.9A worked.
That was with my RK3188 stick. So I tried again with my RK3188T stick and got the same result. I might try with another TV to see if it's an HDMI compatibility issue. I've noticed one other person report the same on this thread. Weird.
On another note, is there any hope that an RK3188T stick will someday run at 1.6 ghz or above on this ROM?
Originally posted by PolloLoco View PostI checked out audio on another TV and hdmi cable, and it worked with this rom. This ROM appears to be incompat ible with the first screen I used, a Motorola lapdock, which is a shame. Neomode 1.9a works with both sscreens.
Yeah it more then likely the t well have working roms for 1.6ghz soon as its just requires fixed overclocking roms which are constantly being worked on by others in this forum.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostLikely this has nothing to do with the rom but more to do with the router/pc not running a master browser.
I rebooted the router and the PC containing the shares. At first it didn't work but after rebooting the stick as well it is working correctly.
EDIT
Whoops spoke too soon. I was able to browse the network, once. I could see a list of all devices on the network. Added Music source, scanned to library, worked fine. Went to add video source, I get Operation not permitted again until I reboot everything again.
I can access the library content I added though.
Wierd.Last edited by imaddiced2u; 11 April 2014, 23:49.HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by imaddiced2u View PostSorry but yes, You need a USB wired keyboard to be able to log to playstore. Enter the username then press tab to advance to the password field.
still other problems are:
reboot the program does not respond to the functions
lack of opportunities disable the device through the button on the toolbar
Logo at startup is not visible
Writes about the old version is not new
None of you that I see no checksMY MINI PC: C4,CS918,M8,M8C
Originally posted by darekmarta1975 View Postkeypad in the system is, but it is not active, now you know. There is only Voice.There is no possibility of activation
Killing a program can also be down from the toolbar by clicking on the button on the right side of the home button and then holding down on the program you wish to close which then pops up with the option to close it.
As for the logo you can install any number of ones you like with ROM Toolbox Lite.Mk802IV Neomode 1.9a original rom 720p
Originally posted by darekmarta1975 View PostYou do not read carefully.
Playstore shows the keyboard is installed
logo is seen by 1sec,check versions old ktkat 4.4, I know what he writes
I am speaking about the closing device of mini pc, I am no a layman
The logo or in this case boot screen is frankly nothing more then cosmetic and something anyone can change.
The keyboard problem he aware of but since this is easly gotten around its not a major issue.
As for shutdown or turning off the device it works fine but on some devices it can cause a reboot instead.
This rom isn't made for every device so some strangeness on models its not made for is expected.Mk802IV Neomode 1.9a original rom 720p
I still know little of the core workings of Android, but that makes no sense to me. RK3066 based hardware, spoofed to host RK3188 FW architecture?
The MK809 had an RK3066 SOC. The MK809 III hosts an RK3188 SOC. What that really is, I dont know...
Sent from my SGH-I337M using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
There are currently 3105 users online. 0 members and 3105 guests.
