Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Ethernet
Hi ethernet adapter work on first pugin.
aftert power off or reboot not work.
i can enable and disable but not ghet IP
only solution are unplur e plug it (i try different port but are some)
i try reboot but not work
XBMC 13 work perfect on HD 1080p video
reboot use alternative app and work
ute alternative app keyboard
bye bye
bye bye
/FredrikMK809III RK3188-T AP6210 running Neomode 3.1
AW: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by Kristoffer View PostIs there any chance of getting this working with the Mediatek wifi version of MK809III?
I can report that the ROM (wifi and bluetooth excluded) works fine.
-Kristoffer
Neomode
Issues with rebooting
After updating to the custom rom, I ran into issues with the screen freezing every few minutes and it caused the device to keep reboot. Is there a fix for this?
Originally posted by neomode View PostHello Guys,
Here it is the New Neomode Custom Rom for the MK809III with Android 4.4.2.
Have Tested this Rom and everything Works like it should with MK809III Version 2 & 3.
The Rom comes with a SD Kernel and a DPI Setting of 160 and is Rooted.
What Works ?
- WiFi
- Bluetooth
- Rotation
- USB
- USB OTG
Software Included:
No-Frills CPU Control
Reboot App from Petrus
SuperSU (Root Access)
Terminal Emulator
FX FileExplorer
Chrome
Chrome UA
This Time the Rom has a Lot of new Features:
Volume Slider Works
Added Power Down Button to Navbar
Hide Navbar Button (Re enable it with Sliding from Top to Bottom)
5Point1 Multichannel
HDMI Passthrough
OC Kernels Included
(To Flash a OC Kernel press the Button in RKFlash Tool where Kernel is then you can Selec New Kernels from OCKernel Dir.)
1,2,4,6 GB Parameter Files Select before Flashing
Download:
New Version:
Upload running please wait 1h.
Old Version:
Regards
Neomode
Ok full review.
Sd Card noice doesn't go away as it should and remains stuck in the top status area.
Overclock roms for T cpu Broken (atleast on the MK802Iv models).
Stock rom fuctioms correctly.
Daydreams feature missing..altough not something thats actually broken its a good feature to have to avoid tv burn in.
Sound options not working correctly with xbmc.
Missing onscreen keyboard (usb keybaord required to download one to fix this)
Option to use hardware keyboard as default not showing.
Rom itself is rock stable on the MK802IV Model T and other then the things noted nearly perfect.Mk802IV Neomode 1.9a original rom 720p
Been trying to get help on the XBMC.org forum but nothing yet, so I thought I'd ask here.
With the 1.7 version of Neomode's rom, I could connect to my server using SMB.
Since updating to the 3.1 Neomode rom I can no longer add an SMB server. When I try I get to the point where the network is selected, in my case called WORKGROUP, then I get an error, Operation not permitted. Does this work for others or is anyone else having the same issue or know how I can resolve it?
HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
There are currently 1840 users online. 3 members and 1837 guests.
