Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by yever View Postmake sure you feel a click when press the button, then plug in the usb power. I actually opened the case, and the button is very small and looks very fragile, so don't abuse it.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostNp
Once you got the windows machince setup with the driver and you done it once its dead simple after that.
Hitting that stupid little buttion the hardest part.!
PS. once installed NeoCR, you can press [Switch] on RKBatchTool1.7 to flash!
Greetings.
Re: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Originally posted by Magnus33 View PostCouldn't make it bigger or easy to hit now could they.
Sent from my GT-I9505 using Tapatalk
Originally posted by warlock09 View PostHello magnus33..or yever...im back...i manage to install drivers..bcoz of your auto driver install i think..so my stick is plug in into the pc found device already..do i have to erase idb first b4 i click on run...by the way...i want the kernel that supports 1080p.can i change it b4 i flash...anybody here..i didnt want to go ahead in case i make a mistake and brick my stick..i am ready to flash now..but still waiting what to do first..erase idb first then click on run..as what magnuss33 said or click run straight away..
[QUOTE=warlock09;176001]Hello magnus33..or yever...im back...i manage to install drivers..bcoz of your auto driver install i think..so my stick is plug in into the pc found device already..do i have to erase idb first b4 i click on run...by the way...i want the kernel that supports 1080p.can i change it b4 i flash...anybody here..i didnt want to go ahead in case i make a mistake and brick my stick..
Sent from my GT-I9505 using Tapatalk[/QUOTE
Yes erase idb and use the kernel of your choice. Browse to your kernel with the box to the right
[QUOTE=Rambler98;176011]Originally posted by warlock09 View PostHello magnus33..or yever...im back...i manage to install drivers..bcoz of your auto driver install i think..so my stick is plug in into the pc found device already..do i have to erase idb first b4 i click on run...by the way...i want the kernel that supports 1080p.can i change it b4 i flash...anybody here..i didnt want to go ahead in case i make a mistake and brick my stick..
Wow...looks good.....testing time..now...thank you ....spoke too soon...why is there no keyboard input method..only google voice typing.i cant input my wifi password..thanks..
[QUOTE=warlock09;176014]Originally posted by Rambler98 View Post
Flash done...info. Run ok...i will try now...the new rom..thanks...
Sent from my GT-I9505 using TapatalkMk802IV Neomode 1.9a original rom 720p
Sent from my GT-I9505 using TapatalkMK808B Plus, MK908II
[QUOTE=Magnus33;176017]Originally posted by warlock09 View Post
Yeah this rom missing a keyboard although you can plug in any usb keyboard to set things up and download any keyboard you like from the playstore..
[QUOTE=warlock09;176020]Originally posted by Magnus33 View Post
Im glad i have spare usb keyboard here ..thank u magnuss33...whats the default kernel on it..does it support 1080p playback..
Its 720 but it can output 1080p more or less.
You can flash D33 kernels which come in both and are overclocked slightly.
Just open the flasher again uncheck everything but the kernel and then click on the tab to the right of the kernel to select any you wish.
The device needs to be in flash mode but nothing else needs be done as you can change kernels without changing roms or settings
Just click run when its in flash mode and seconds later your done.Mk802IV Neomode 1.9a original rom 720p
[QUOTE=Magnus33;176036]Originally posted by warlock09 View Post
[QUOTE=warlock09;176037]Originally posted by Magnus33 View Post
Which of d33 kernels are with 1080p..i wnet to forum there are choices and i dont know which one..thanks.
AP6210-HD.Mk802IV Neomode 1.9a original rom 720p
There are currently 2635 users online. 0 members and 2635 guests.
