Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    AW: Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
    Or take a look here
    Neomode
      Originally posted by neomode View Post
      I Start to Work on Version 3.2.
      Any wishes from the Community for the next Version?
      Neomode
      will it fully support for that MK802IV?
        Should be because nearly same Hardware.
        Neomode
          Thanks for all your work neomode! How about a "close all open apps" in the multitask window?
            This is some off-topic, but:
            Flashing with different ROMS around the www, there are some of them that let you flash using the "SWITCH" button in RKAndroidTool to enter "Flash mode" instead pushing dongle button. I thought this was defined on each devices (as "read-only" setting), but just in this month I have used 3 different methods to get into "flash mode" like:
            - Normal one: pushing hidden button on the dongle.
            - Chip shortcut: join 5-6 & 7-8 lines on the chip directly.
            - GUI one: using RKAndroidTool/BatchTool "Switch" button.
            Is there a way to define a "flash mode" method on the rom?
            Greetings.
            MK809III clone (T model) + d33 Kernel v4.1 {OC'ed kernel mod} (1.7Ghz/768/800Mhz) !!!
              Neomode
              Yeah, a new version for MK802IV with AP6210...
                How about adding It yourself?
                It's easy :
                - install xposed framework http://forum.xda-developers.com/xpos...fying-t1574401
                - install Gravitybox kitkat module for the framework
                - enable close all and other great tweaks Gravitybox has to offer.
                The Xposed framework is a must have IMHO, it has so much to offer!
                Enjoy!
                Regards
                  Neomode
                  It may not be possible because I suspect it's a kernel issue, but can you add the original audio drivers as an option under settings?
                  One of my screens works great with your 1.9a ROM and kernel but I get no sound with this rom and D33's kernel. D33 explained that the new audio drivers require the screen to report back audio capability. Mine must not. It's a long shot, but I was wondering if it was possible to use the old settings as an option. I understand if it's not possible.
                    Neomode
                    Well a Dvb-t driver will be nice
                    And a version for MK802IV new wifi
                      It's easy :
                      Enjoy!
                      Regards
                      Thanks for the tip! I will check it out!
                        Neomode
                        I totally forgot to add these on previous list:
                        - WifiDisplay
                        app: is it possible to make it work? I tried to install it unsuccessfully ...
                        - Send-to-bluetooth: function doesn't appear, dongle is only working as file receiver.
                        Greetings.
                          What didn't work in 3.1.
                          Location services had to be setup or it can't be turned on later.
                          Screen scale...this one odd since with my lg its worked fine (TV set to 16:9)
                          Day dreams and cheapcast missing..Daydreams actually does seem to still be in the rom but the controls are missing.
                          Cheapcast i am iffy on since developer support has been yanked so is it worth including?
                          Onscreen keyboard missing of course
                          Rom doesn't seem to default to hardware keyboard or notice its there so they can't be set as default(they do work though)
                          Boot screen..but really its cosmetic.
                          Rom... the overcloc didn't work correctly on the T versions but with all the work D33 done there probably not needed now.
                          The 3.1 rom actually works very nicely otherwise
                          With so little need for improvment maybe blink out the rom?
                          PS: dont take to long iam going in for arm surgery may 16 so flashing after that going to be darn hard with one hand...lol.
                          All though my better half may hurt herself laughing watching me try
                          Mk802IV Neomode 1.9a original rom 720p
                            check if you have : /system/media/bootanimation.zip
                            remove or rename it to something else if you have it, then you will get the default android boot animation. You need to mount /system as RW of course.
                            It seems that the file bootanimation.zip is not compatible with the ROM.
                            MK808B Plus, MK908II
                              I just use romtoolkit lite from the playstore to put one of its many boot screens on.
                                that works too. I just like the simple android boot animation.
