Neomode Custom Rom MK809III Version 3.1 Android 4.4.2 *Update*
Anyone tested this new KitKat rom released yesterday, is it better than the Geekbuying one or the same?
KitKat_T010_AP6210_public_20140403, Geekbuying one was released 20140331.
Edit: It has bootloader v2.13 and most Google apps, busybox and Broadcom AP6210 wifi.
If only someone knew how to communicate with all these people that upload new roms to Baidu it would make it so much easier to get the correct and newer roms for all our different devices.
The release will come this weekend.
I will release Both Version for MK809III and the MK802IV both with AP6210.
Neomode
Thanks Neomode for letting us know that the new 3.1 release will come this weekend... Great News!!
I always have succesfully used all your MK809III/AP6210 with my CX-919 v2.0 (FULL MK3188 not T), but since you will be releasing both versions for MK809III and MK802IV, I would like to know wich of these two versions you think it will work better with my CX-919 or if you think that I should test both of them?
Good News for all Version 3.1 is on the way.
Volume Slider Fixed
HDMI Passtrough
Rooted
Antutu Score is 19000 @ FullHD with 1.6 GHz.
Neomode
Sounds grrrrrrreat!
Please say that 3.1 will be able to oc rk3188-T. Is it possible to have an oc kernel that dont have a high "lower ghz limit". The one i use now limits the lowest ghz to 1.2Ghz and highest to 1.42Ghz. This causes my mk809iii to run hot (I think) and crasches after a while. Is it normal to have the lowest limit set to 1.2Ghz?
Works great soo far on my mk802 iv rk3188-t. The only issue I found is the camera doesn't work. But it does not work on fineless either. Is this fixable ?
my wifi and bluetooth are not woking after upgrading from 4.2.2 to 4.4.2 firmware. when i was using 4.2.2 firmware i didn't have any problem. can you please help me.
regards.
my device is MK809III and there is a writing on front of the device it says Android mini PC
