.gif)
Minix official release the NEO X8 and X8S Quad Core Android TV BOX Power By Amlogic S802 and S802H
We need a standard checklist anytime a new device is being reviewed that way there isnt a million random questions and answers sprinkled throughout the thread / subforum. Here are a few things that I consider important in testing a new device. If MINIX, Geekbuying or anyone else can answer these questions then it should give a decent overview of the performance in comparison with other s89 devices (which is where most of all of these bugs were pulled from).
Networking:
(1) Ethernet speeds - What are they in comparison with other devices on the same LAN?
(2) 2.4ghz / 5ghz speeds - What is the range? what are the speeds in comparison with other devices on the same WLAN?
(3) Bluetooth - What is the range? Are devices remembered after a reboot?
(4) Mac addresses for Wifi / Eth / Bluetooth - Do they retain the same address after a reboot?
(5) NFS and CIFS protocols - Are they supported? do shares mount correctly? - Confirmed these protocols are not working with current MINIX kernel.
GUI:
(6) Brightness of display - Is it adjustable? is it hard coded? if so, is it within normal range or too dark / light?
(7) Orientation - Do all apps force to landscape or do we have the portrait bug doing its dance?
Video / Audio:
(8) Audio pass through - MX player, XBMC and stock video player is it working? which formats are being decoded correctly?
(9) Netflix quality - Is it HD? Does it support dts? - Confirmed Netflix playback is ONLY in SD (appears to be an issue w/ Netflix and not the device itself)
(10) Resolution / Refresh rate / FPS - Is video playback smooth with all resolutions / refresh rates? Does video playback smooth @ 1080/24 on a 50 or 60hz TV? Are we seeing dropped frames?
(11) File formats - MP4, AVI, MKV AND ISO/3D ISO? (How do these play w/ Amcodec enabled? I know there are many other factors involved but a basic test should be sufficient)
Hardware:
(12) USB Storage - Which FS are supported out of the box?
(13) LED - Does the devices led remain on even after the unit is shutdown / is it too bright?
(14) Standby - Does box wake itself from standby automatically?
(15) Keyboard - Which air mouses / keyboards are confirmed working with functioning key layout?
(16) Heat test - Run a slot machine game (or really any other CPU/GPU intensive app) for 10 minutes straight and check temp by hand - is it cool? is it warm? has performance been effected?
(17) HDMI input / output - Does video cut out randomly or not display at all after a certain period of time / moving the cable?
(18) Webcams - Does it support webcams? if so, which models have been tested and are proven to be working?
(19) Power consumption - What is it during idle / load? Is it steady or do we see spikes?
Software:
(20) CPU frequency - What is minimum? Does it scale correctly if rooted? - Kernel is confirmed to still have a min frequency of 24mhz
(21) Kernel - Is it still meant for a smart phone or has it been optimized for ATVs? -- Kernel is confirmed to still be optimized for a smart phone and not ATV's
(22) Flash video - Does firefox work properly with flash?
(23) Date and time - Are they able to be changed to areas outside of china? Does it retain this settings change after a reboot?
(24) Paid apps - Can you purchase or install paid / previously paid for application?
Feel free to add anything else you can think of guys. If we can get the list up to 25 questions we can assign each question a weight of 1-4 and try and get a rough estimate of where it lands on a scale of 1-100.Last edited by alwaysbless; 01 June 2014, 18:26.
Re: Minix official release the NEO X8 and X8S Quad Core Android TV BOX Power By Amlogic S802 and S802H
Originally posted by alwaysbless View PostWe need a standard checklist anytime a new device is being reviewed that way there isnt a million random questions and answers sprinkled throughout the thread / subforum. Here are a few things that I consider important in testing a new device. If MINIX, Geekbuying or anyone else can answer these questions then it should give a decent overview of the performance in comparison with other s89 devices (which is where most of all of these bugs were pulled from).
(3) Audio pass through - MX player, XBMC and stock video player is it working? which formats are being decoded correctly?
(4) Bluetooth - What is the range? Are devices remembered after a reboot?
(5)Mac addresses for Wifi / Eth / Bluetooth - Do they retain the same address after a reboot
(6) Orientation - Do all apps force to landscape or do we have the portrait bug doing its dance?
(7) USB Storage - Which fs are supported out of the box
(8) Netflix quality - Is it HD? Does it support dts?
(9) LED - Does the devices led remain on even after the unit is unpowered / is it too bright
(10) Brightness of display - Is it adjustable? is it hard coded? if so, is it within normal range or too dark / light
(11) Flash video - Does firefox work properly with flash?
(12) File formats - MP4, AVI, MKV AND ISO - How do these play? (I know there are many other factors involved but a basic test should be sufficient)
(13) Standby - Does box wake itself from standby automatically?
(14) Keyboard - Which air mouses / keyboards are confirmed working with functioning key layout
(15) Heat test - Run a slot machine game (or really any other CPU/GPU intensive app) for 10 minutes straight and check temp by hand - is it cool? is it warm? has performance been effected?
(16) Paid apps - Can you purchase or install paid / previously paid for application?
(18) CPU frequency - What is minimum? Does it scale correctly if rooted?
(19) Kernel - Is it still meant for a smart phone or has it been optimized for ATVs?
(20) Webcams - Does it support webcams? if so, which models have been tested and are proven to be working?
(21) Date and time - Are they able to be changed to areas outside of china? Does it retain this settings change after a reboot?
Sent from my Nexus 5 using Tapatalk
Originally posted by Batfink32 View PostGood questions. If track record has anything to do with it then I imagine the X8 will need the help of the devs from here to fix its problems.
Minix official release the NEO X8 and X8S Quad Core Android TV BOX Power By A...
(12) File formats - MP4, AVI, MKV AND ISO/3D ISO? (How do these play w/ Amcodec enabled? I know there are many other factors involved but a basic test should be sufficient)
(22) Power consumption - What is it during idle / load? Is it steady or do we see spikes?
(23) Resolution / Refresh rate / FPS - Is video playback smooth with all resolutions / refresh rates? Does video playback smooth @ 1080/24 on a 50 or 60hz TV? Are we seeing dropped frames?
(24)
(25)
Originally posted by MINIX View PostInteresting... usually we provide our sources to developers because they think ours are bettter...RK3288 Devices
- Overview BOX (LINK !)
@alwaysbless
"(15) Heat test - Run a slot machine game (or really any other CPU/GPU intensive app) for 10 minutes straight and check temp by hand - is it cool? is it warm? has performance been effected?"
That is a great list to use a reference. Fos consistency sake, what slot machine program are you using? Does it have a good attract mode so it can run without interaction? Thanks.
*List has been updated with some findings per bobs ported MINIX rom.*
Networking:
GUI:
Video / Audio:
Hardware:
Software:
Also if this is directed only at Minix? My thoughts are if you want to really make this work a new post with device reports by name.
Originally posted by Finless View PostYou should make this a new post honestly.....
There are currently 2001 users online. 0 members and 2001 guests.
