New Nextbook Models for 2014 (Quad Core RK3188)
Good point... I don't think else pointed out that having the android SDK installed and ADB working is a prerequisite...
ShaunMTFreaktab Rom Developer
Originally posted by biffsteele View PostIs there any way to divert some or all internal SD space to app storage space other than just moving apps to SD card? Thanks!
Stay tuned...
Originally posted by biffsteele View PostI had to disable Norton 360 to get MoBo and Kingo to install properly. Then had to get MoBo talking to tab first then Kingo worked great.
FYI - Getting Root or Fastboot Mode Working is Required
The only way to flash the RK3188 models will be to get Root or Fastboot mode working first...
Eventually, a custom recovery can be installed internally, but the only way to install anything without custom recovery is to have root access or get fastboot mode working in order to use the RKFlash tool.
Originally posted by shaunmt View PostNot without a custom ROM or patch... but at least the partition map isn't hard coded into the kernel on this model.
Stay tuned...
ShaunMT
Originally posted by biffsteele View PostHad 4 or 5 play store updates that kept saying insufficient space, then remembered about Link2SD from my Optimus S days. Appears to work fine upped my internal memory from 110mb to 430mb or so. Not a Devby trade but if u need a tester ...
When I get custom ROM made for this model, I'll probably reallocate half the internal SD space to /data instead. I'll probably provide the option to move the entire internal SD space to /data and use the external SD card as the only SD card also.
There are currently 3044 users online. 0 members and 3044 guests.
