New Nextbook Models for 2014 (Quad Core RK3188)
I don't have a lot of experience here, but I've read that if you flash the stock ROM and stock recovery back onto your device, you can get your OTA back. I just picked up my Nextbook last night, and I plan to play it safe and keep everything stock, not even root. The website says July 15th will be the update. I can wait a little over a month.
Originally posted by B-Man View PostI don't have a lot of experience here, but I've read that if you flash the stock ROM and stock recovery back onto your device, you can get your OTA back. I just picked up my Nextbook last night, and I plan to play it safe and keep everything stock, not even root. The website says July 15th will be the update. I can wait a little over a month.
Will wait to see how their KK ROM is (if it actually comes as indicated)... maybe most of us won't want much more than Root access then...
ShaunMTFreaktab Rom Developer
Originally posted by B-Man View PostThanks for everything shaunmt. I hope you plan to work on it shortly after the update, and I hope I can wait that long.Freaktab Rom Developer
Originally posted by B-Man View PostSo I just installed as many of my apps as possible and even moved as many as possible to the internal nand storage. I am out of space already. This will be a long month or two.
Personally, I don't even want the internal SD partition... I'd rather have all that space as data and use an external SD only.
They also make the system partition too damn big... what is the point of so much extra space in a read only partition?Freaktab Rom Developer
Originally posted by shaunmt View PostYup... don't know why they make data partition so small on these...
The website says it supports up to a 64GB SD card. Do you think that's a hardware or software limitation? If it's software, do you think it'd be possible to make 128GB cards work? I'd love to put as much of my music locally on my Nextbook as possible.
Originally posted by B-Man View PostThe website says it supports up to a 64GB SD card. Do you think that's a hardware or software limitation? If it's software, do you think it'd be possible to make 128GB cards work? I'd love to put as much of my music locally on my Nextbook as possible.Freaktab Rom Developer
Originally posted by Perfectpitch View PostIsn't there a way to make your sdcard and ext of the data partition by formating it to ext4 and mounting it?
Sent from my NX785QC8G using Tapatalk
I think the main problem with this is that Android isn't designed to support apps on a "secondary" SD card... which means you have to either swap the internal and external cards or get rid of the internal SD card entirely so you can use a bigger external SD as the primary.
NextBook 8 jelly 4.2.2
i bought it today, and im trying to figure how to root it, ive tried many things and nothing yet, im running windows 8 idk if that would affect my process of rooting the tablet. tried installing ADB drivers, moborobo, the Micro SD card method, shuame, the other one king something i cant remember the name lol but no luck at all. sucks cause this is my first android device and i would love to have it rooted, cant friggin jailbrake my iphone 5s D: i suck at this to be honest.
Originally posted by Ferbrizio View Posti bought it today, and im trying to figure how to root it, ive tried many things and nothing yet, im running windows 8 idk if that would affect my process of rooting the tablet. tried installing ADB drivers, moborobo, the Micro SD card method, shuame, the other one king something i cant remember the name lol but no luck at all. sucks cause this is my first android device and i would love to have it rooted, cant friggin jailbrake my iphone 5s D: i suck at this to be honest.
Getting the correct drivers installed was the challenge. I don't recall how I finally got the correct drivers.
I do think it involved turning my firewall / antivirus off to get the installer to work correctly though.
I used moborobo + kingoroot to root my tablet. @Ferbrizio, how are you doing it? From what I remember I installed the proper driver using moborobo. After the driver is install, try using moborobo to install some app just to make sure it's working. Then open kingoroot (don't close moborobo app) and root the tablet. Let me know if this method works.
Originally posted by B-Man View PostAfter a few days with mine I finally decided to root yesterday. I can confirm Kingo works, it calls the tablet by the wrong name tho meaning my wife Windows 7 machine (I have a Mac) must have grabbed drivers for the previous model 8 inch Nextbook. It worked tho.
Most Nextbook build.prop files I have seen still contain a line referring to a Prestigio PMP5580 (also made by Yifang and sold by one of their subsidiaries).Freaktab Rom Developer
There are currently 2552 users online. 0 members and 2552 guests.
