New Nextbook Models for 2014 (Quad Core RK3188)
HI i'm new here i have one these first time ever owning a tablet and was wondering if it is safe to have plugged in while watching netflix movies, and also charge from like my car on one those universal chargers. can someone help me out. nextbook just gives some stupid lame brain answers like its not designed like this i'm sorry for your battery life.
Re: New Nextbook Models for 2014 (Quad Core RK3188)
Originally posted by TonyB123 View PostHI i'm new here i have one these first time ever owning a tablet and was wondering if it is safe to have plugged in while watching netflix movies, and also charge from like my car on one those universal chargers. can someone help me out. nextbook just gives some stupid lame brain answers like its not designed like this i'm sorry for your battery life.
Sent from my SM-G900P using TapatalkFreaktab Rom Developer
Originally posted by TonyB123 View Postyes its NX785QC8G ON THE box says nextbook 8
This is only charges via a usb cable with an ac adapter...
In my experience, it does not charge properly unless you use the ac adapter that came with it, although it might be possible to find compatible adaptors...
Mine will not charge correctly using my samsung adaptors.
Assuming you use a compatible adapter, it should be on to leave it plugged in while using it. You might want to watch the temp though... these tablets dont have active cooling so they can get extremely hot very fast when playing video or gaming...
Shaunmt
Shaunmt
Originally posted by TonyB123 View Postok so as long as i use the charger that came with it and watch the temp it should be ok. i do have a adapter that says it 5.0 to 5.5 v would this work to charge in car?
This tablet seems to be very picky about its power input... I suspect the software disables the charging circuit if the input is out of range.
Originally posted by TonyB123 View Postok i will i was looking at the wall adapter its 5.0 v 1.5 amp so i will see if the one i have is 1.5 amp if so it should work theoretically, just looking for options for my daughter when we go on trips so we can charge it.
Originally posted by shaunmt View PostYou might have luck finding some perfect matches for cheap on amazon... I havent looked for any for this model, but have gotten replacements for other models for under $10.
Originally posted by TonyB123 View Posti will check that is there any way to root this model so i can remove the built in apps i don't need or use.
Originally posted by TonyB123 View Postyes thanks a bunchalso since you own one these as well can i leave on all the time and charge like i do my cell phones.
Originally posted by shaunmt View PostProbably.... havent used mine that much yet though... might shorten your battery life (as with any battery device)... check to make sure it doesnt get hot just from being lwft plugged in.
according to this page http://www.nextbookusa.com/productde...?product_id=19 we are suppose to be updated to 4.4.2 but the tablet keeps saying the current version is the latest version, has anyone dowloaded the image from the support page here. http://www.nextbookusa.com/download.php rhis is for the nextbook 8 model NX785QC8G
There are currently 2505 users online. 0 members and 2505 guests.
