I have an M9 Pro (mine) and an M9 Max (wife).
Recently the Max was shutting down as soon as it was turned on. We thought it was the battery, so I bought and installed a new battery. However, after installing the battery and charging it, the problem was the same.
If I reset (paper clip) the tablet, the RileyROM and boot screen would come on then it turns itself off.
I have tried to fix the issue by re-flashing with 2.5.3 (currently on 2.1). I can get the flashing tool to recognise the Max by using the ESC/RESET/POWER 5 second combination, and can erase the IDB (erased the IDB 4 times, just to be sure).
However, when I click on "Reboot to Flash Mode", I get the message :
"Device can not do switch, because it is not MSC device". The Max screen is black.
Anyone seen this before? Or have any ideas on how to fix the problem?
