Pipo M9 Max RileyROM 2.5
Re: Pipo M9 Max RileyROM 2.5
Originally posted by remi252 View PostRandy
Bluetooth keyboard
Hi again. I encountered some problems when i tried to use my Bluetooth keyboard. I can pair both devices, but then i can only use the keyboard for a minute or two, like in the first firmware releases. It worked well in the previous version, Is it something that you could fix? If it is difficult or impossible for you i would want to ask for an inverted y axis version of the 2.4 and not of the 2.5.1, because i use that keyboard a lot. Thanks for your time!
Wow, I forgot I needed to do that. I'll work on that for you guys.Randy
Originally posted by zaisen View PostWhat The f##k!?!? This is amazing muy Pipo dont get more of 2 days with médium use and 3 without use... But i dont know that kernel i'm using... Can you link the kernel please??
See you
EDIT: Is this the kernel? http://www.FreakTab.com/showthread.php?t=7891
kernel696.zip
Did you flash 2.5.1 with the 2.4 kernel? That's the way to get this ROM going.
Sorry, I've been a little distracted learning a new platform (MTK devices)...and I forgot to fix this ROM. It looks like my ballgames will be rained out tomorrow, so I hope to get it fixed then.
Sorry for the confusion.Randy
Homebank app not working on 2.5.1
Dear Riley,
i was also a bit confusing about that, but no worries, that happens. I flashed with the dnkn kernel, as it seems the battery life is quite amazing, i will see.
However, i don't know if it comes from that kernel or something else, but since i updated my tablet to this 2.5.1 version, my hombank app isn't working any more (ING Belgium). I am able to start it, configure it, but when it comes to finalize the registration, i get a FC and the app stop working. I will try to flash the kernel from 2.4 and see what happens, but if it is still not working, what information do you need to check what is the issue ? This app was working fine with the 2.4, that's the reason why i am wondering about this FC. Thanks for your help.
Originally posted by rrileypm View PostDid you flash 2.5.1 with the 2.4 kernel? That's the way to get this ROM going.
I assumed the download in the first post had been corrected, so no I didn't.
Copied kernel from 2.4 but it's kept all my settings. Different boot screen and in system it says 2.5.1 so I assume that is correct, just need to wait for new kernel?
Actually, in post #35, there is a link to the actual kernel for this ROM/firmware.
Stay tuned...I will be posting 2.5.2 with the working kernel.Randy
v2.5.2 available
Just go to the download link in post #1 and get v2.5.2.
This version contains the working kernel for this version of the firmware. I know that some of you were using the kernel from the 2.4 ROM...but this is the actual updated kernel (same one posted in post #35).Randy
Nope, it's the stock kernel.Randy
Originally posted by rrileypm View PostJust go to the download link in post #1 and get v2.5.2.
I take this opportunity to Thank All You Guys that work on all these different Tablet rom's.
Regards JBF
There are currently 2488 users online. 0 members and 2488 guests.
