Pipo M9 Max RileyROM 2.5
    Why do you guys even bother with stock kernels when its so obvious they are crappy... I use the 696 kernel posted above and i get around 22 000 in antutu and if i don't use the tablet too much it can go up to 13 days without charging?
    What are u people so scared from to use an OC kernel??? Its a cheap chinese tablet for Christ's sake...
      Well, in my opinion...stock kernels aren't that bad...and benchmark scores are just a number. There are pros and cons to switching kernels...and it all really depends on what you do with your device. I for one, am the first person to try every RILEYROM. OC kernels don't even exist yet before I release a ROM. If the ROM isn't good enough for me...with a stock kernel, then it's not good enough to be released with my name on it.
      That being said, there are always users who want to see a higher Antuto score, or a faster clock speed. There are other who like an underclocked kernel to save on battery life.
      I enjoy the happy middle...for stability.
      I have high respect and appreciation for our kernel guys...but I see their frustration in trying to please every type of user. Plus, due to the variations in CPU quality, not every device benefits from the 696 kernel the way yours does.
      It's just the nature of the Android beast.
      Randy
        About O/C kernels, not everybody can use them!
        In my case, I've a new M9 max with a goodix screen and custom kernels released here doesn't works (no touchscreen).
        The only way for me to use an undervolted or overclocked kernel is to patch a stock kernel. (-75mv 1608MHz + DDR @ 720MHz -> 1704Mhz CPU freeze after some minutes of use!)
        I started to check the 2.5.x system.
        Pipo finally patched framework-res.apk to solve the auto-brightness problem with the sensor from latest M9 Max batch (screen was becoming totally black when brightness was set to auto-mode )
          Well fair enough, as indeed there are those for whom custom kernels don't work, that is a different story.. I at least was on the lucky side to be able to get the extra speed and the extra battery at once..
          For the rest i guess there have to be volunteers that are willing to try and create a different kernel for each of the few existing tablet variations, so that every1 can experience the benefits that some of us do.. Only this way we can continue the legacy of the beastie Chinese tablets
          P.S. Although i can enjoy the extra juice the 696 brings me, my tablet has its issue as weell, every time i play a 3D game, almost always in the shadows and darker areas, i get these little blue dots that look like noise on the image... And usually they affect the performance and lower it a little bit... I have tried with every kernel and ROM but none made a difference... So we are all cursed to suffer 1 way or another
          P.S. 2 In the previous thread (2.4) i was asking for advices on how to safely open the tablet to clean the screen from dust under... After no reply's i grew the balls, opened it up with some sweat, and cleaned it, then i sealed the whole thing with thick tape inside in every area that dust can go through, so now i am finally enjoying a dust free premium experience
            Help !!
            I will look into that. Right off hand, I don't remember where that setting is. I'm traveling out of town this weekend, so hopefully I can post a solution for that early next week.
            Thanks for your support!!!!!!!!!!!
            I am one of many affected by the problem of tactile inverted in the Y axis. In 4pda.ru forum found a kernel that I used in the RileyROM 2.4 and it has worked perfect, but I would like to see my Pipo M9 with RileyROM 2.5.2
            In 4pda.ru give the following as a route to recompile the driver ct363:
            /drivers/input/touchscreen/ct36x/ct363.c
            And this is the edition required:
            ct363-> x = ts-> orientation [0] * x + ts-> orientation [1] * y;
            ct363-> y = TS-> orientation [2] * x + ts-> orientation [3] * y; / / These lines Immediately after ct363-> x = TS-> x_max - ct363-> x; / / Axis "x" ct363-> y = TS-> y_max - ct363-> y; / / Axis "and"
            I hope this could help you to solve soon
              Re: Pipo M9 Max RileyROM 2.5
              Originally posted by babyboy3265 View Post
              This is the kernel im using... Also i am using some other tweaks like "android tweaker 2", its in the play store... Check it out, i also disabled some services from games and apps that were constantly running and i didn't need, with "disable services" also in play... Try them out and let us know how it worked out for ye
              [ATTACH]6348[/ATTACH]
              What settings did you use in "android tweaker 2"? I am trying it out with the 696 kernel.
              Sent from my GT-N7100 using Tapatalk
                I also need a kernel with inverted Y axis.
                Help me please!
                  Is this ROM actually 100% for a normal user (like me)?
                  What are the differences between 2.5.2 and the 2.4?
                  Thank you so much Randy and collegues
                    Big step forward regarding WIFI
                    For me, this 2.5.2 Version
                    finally solved WIFI problems
                    All and every earlier rom gave me
                    random loss of wifi Connection
                    hangs and problems with settings
                    for BT and wifi
                    3G is also running fine now
                    GREAT :-)
                      Speeding up M9 Max
                      in this post
                      user Kandilak laid out a way to speed up the M9 Max by using Mounts2SD.
                      I have 2 questions now:
                      1.) Is this method still of benefit to the 2.5 ROM?
                      2.) If you have a M9 flashed with the 4GB RAM, will you loose all that 4GB on the real internal RAM with this method?
                      If so, would it not be good to flash this new ROM with as small a RAM partition as possible, f.e. a 256MB RAM, so that the internal SD card then becomes bigger and the space is not wasted?
                      Or would 256MB be too small and maybe 512MB would be better?
                      What changes in the boot files would need to be done to achieve flashing such a small ROM?
                      Sorry about so many questions, but I am always tight on SD space, as probably many others too .
                      BTW has anyone tried to use the M9 Max with a 64GB card - did it work or is 32GB th emax?
                        Can't comment on your other questions but my M9 is quite happy with a 64gb microsd.
                        Sent from my GT-I9300 using Tapatalk
                          link to official firmware
                          Hi Randy, I found the official link for the M9Max (same as the dumped ROM)
                          Maybe you can compare this Firmware with the dumped ROM
                          update#117_DS1006_PIPO_1.0.13_3G_NOMMS_20140213.im g
                          百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                          565 Mo (592 740 668 octets)
                          Build.prop from this Firmware
                          ro.build.display.id=rk30sdk-eng 4.2.2 JDQ39 root.20140213.094848 test-keys
                          ro.build.version.incremental=root.20140213.094848
                          ro.build.version.sdk=17
                          ro.build.version.codename=REL
                          ro.build.version.release=4.2.2
                          ro.build.date=2014年 02月 13日 星期四 09:51:06 CST
                          ro.build.date.utc=1392256266
                          ro.build.type=eng
                          ro.build.user=root
                          ro.build.host=lzj-desktop
                          ro.build.tags=test-keys
                          ro.product.model=M9
                          ro.product.brand=PIPO
                          ro.product.name=rk30sdk
                          Something strange: longliuyanglin add this Firmware for the M9Max just today but it is an old Firmware...
                          Maybe this one could help some users who has problem with the X/Y inverted (old pcb) ?
                          I let you the link
                          M9_pcb_1.1_20130527_Android4.2_No3G_chinese_update #95.img
                          http://pan.baidu.com/s/1ntHP0hV
                            Thanks. I just may redo the ROM from this firmware. It will have to be tomorrow, though.
                            Randy
                              Could somebody please answer on my post a few items back? I would appreciate it very much:
                              Hi,<br />
                              <br />
                              in this post<br />
                              <br />
                              http://www.freaktab.com/showthread.p...l=1#post139362<br />
                              <br />
                              user Kandilak laid out a way to speed up the M9 Max by using Mounts2SD.<br />
                              <br />
                              I have 2 questions now:<br />
                              <br />
                              1.) Is this method still of benefit to the 2.5 ROM?<br />
                              <br />
                              2.) If you have a M9 flashed with the 4GB RAM, will you loose all that 4GB on the real internal RAM with this method?<br />
                              <br />
                              If so, would it not be good to flash this new ROM with as small a RAM partition as possible, f.e. a 256MB RAM, so that the internal SD card then becomes bigger and the space is not wasted?<br />
                              <br />
                              Or would 256MB be too small and maybe 512MB would be better?<br />
                              <br />
                              What changes in the boot files would need to be done to achieve flashing such a small ROM?<br />
                              <br />
                                Sorry, I'm not familiar with that setup. I'm not sold on the idea that your tablet can run faster by moving everything to external SD.
                                Randy
