Pipo M9 Max RileyROM 2.5
Here you go:
With a rooted explorer app, go to system/media and cut/paste the current bootanimation.zip somewhere (external SD is a good place). Don't just delete it.
Rename this file bootanimation.zip and copy it to the system/media folder. Set read/write/execute permissions.
It should appear on reboot.Randy
Originally posted by rrileypm View PostThe default parameter file is the same as the 4gb parameter. No need in doing that.
As far as camera goes, I think other people have had problems with the default camera app. Try using one of the free camera apps from Google Play Store and see if one of them will work.
On the 2.5.3 I notice some slow ups and launcher crashes from time to time. Any suggestion to which version before 2.5.3 I could try reverting back to?
Originally posted by rrileypm View PostWhat is the format of your micro SD? You can try formatting it as NTFS and see if the problem persists on 2.5.
I installed the new 2.5.3. I formatted the MicroSD card on my tablet with version 2.5.3 on PC then format ntfs and I still have the problem. I read on a forum French there was one who had the same problem as me but he resolved it by checking the first box, which I also did but still the problem except the first reboot.
I think I'll wait for another updates.
thank you
thank you
Originally posted by Meegolo View PostYou think it comes from there. For it is true that I have not disassembled before.
i.e. umount the card, remove it (need something small to push down on the card, to make it pop up), re-flash the ROM again.
Wait for the tablet to re-boot and settle down.
If everything appears to work, then install the SD card and re-format it (NTFS).
Good luck.
Good luck.
Originally posted by Meegolo View PostIt does not work.
Have you tried to re-flash the tablet using the default settings in the ROM_Flash_Tool_147?
Also be 100% certain that the ROM matches the tablet.
My wife has a Pipo Max-M9 Pro. The first time I tried to flash it I used a RileyROM for a Pipo M9 Pro. I thought I had bricked it. However, once I realised my mistake, I re-flashed with the correct RileyROM and all was good.
You will find a lot of warnings in threads that Randy Riley has started regarding correct procedure, unbricking tablets, etc. I don't think you have bricked the tablet. Just go back to basics. Follow the Beginners Instructions.
Good Luck.
Originally posted by Nordo View PostWhat I was trying to say was leave the micro SD card out until you get the tablet operating normally.
Good Luck.
I removed the Micro SD, I flashed 2.5.3 with ROM_Flash_Tool_137. I made a ERASE ID, if I'm not mistaken, then Flash Rom. I waited until everything is installed and operational. Once the android tablet I could put my Micro SD. The it is detected but if I tin my tablet then starts again once arrived android is no longer detected.
My tablet is the Max-M9, not the Pro. I have taken the first rom post.
With version 2.4 I do not have the problem. I did not start in the root tablet.
It is a pity that I can not make it work with V2.5.3 for my Pipo is faster at startup.
Thank you
Micro SD Problem
Thank you
I think you need someone better than me to help you.
Can anyone help?
need help
I downed the 2.5.3 pipo max m9 which is my tab but the rkmultiplayer does not support hidef and seams to be default player and I don't know what to doComcast said you might be able to help. the player will not play my to go app need hidef codec .I love the rom it is smooth and works fine other wise. although 3g is still active searching my tab does not have 3g and I was told it will not work in us anyway(not realy affecting battery life it is better than stock rom was) I do not have any other roms I got this off **** with one of your roms already on it. thanks for any help with the player.
What are the differences between the latest version and 2.4 (if there are no real differences I don't want to replace the FW because the M9 belongs to my mother and she'll be annoyed if she loses her games)? Most importantly, has the issue with the slow internal storage been fixed (the Chrome browser is practically unusable, showing ANR dialogs all the time and sometimes ANRs show when switching between apps).
There are currently 2425 users online. 1 members and 2424 guests.
