Sent from my mobile device. Please excuse any typos.
Tronsmart Vega s89 Standard/Elite FAQ - READ THIS FIRST
Re: Tronsmart Vega s89 Standard/Elite FAQ - READ THIS FIRST
Updated the FAQ a little, but there is still things I know that I'm forgetting to add.
If anybody has suggestions I'd be happy to add them.
Can someone explain why it isn't possible at the moment to install paid apps?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostCan someone explain why it isn't possible at the moment to install paid apps?
Currently the firmware supplied by geekbuying (04/08/14) does not allow paid apps to be installed. This has been reported and new firmware will be released soon.
You can restore paid apps using Titanium Backup to your device, it appears they work just fine this way. (Thanks roolmapoo
So its missing files from the rom,
from what i understand,
Which isnt very much lolMXQ Amlogic S805
VOYO Mini PC Windows 8.1 Intel Z3735F
Tronsmart Draco AW80 Telos Allwinner A80
-Finless ROM 1.1 - BETA2
Tronsmart Vega S89 Amlogic S802
-Finless 2.1 ROM
Originally posted by noderat View PostThis won't be in your options, dmesg is something you run in terminal that displays important logs about your system.
Originally posted by nutzu View Postso is there a way to know if I have a dud ethernet.?node rat u have one can u connect to ethernet?
1a. Connect device via micro-USB-cable at OTG-Port at the device with your PC
1b. Plug power to your device (maybe starts up automatically)
Because I'm not receive my device until now, I'm not sure, if this is available by default:
1c. Settings -> [SYSTEM] Developer options -> Enable USB debugging
(If not you have to klick more than once at "Settings -> [System] -> About device -> [Build number:]" to enable it)
(reboot)
2. Install (like for the amlogic_tools) via moborobo the needing driver at PC
(http://www.tronsmart.eu/downloads/)
Because I'm not receiving my device until now, I'm not sure, if this version works:
3. ADB by neomode
4. follow the step at Post #1
Follow this guide to get your DMESG.RK3288 Devices
Originally posted by chrisnkazz View PostGoogle Play Store Paid Apps
1. does not allow paid apps to be installed.
2. You can restore paid apps using Titanium Backup to your device
3. So its missing files from the rom, from what i understand,)
But I'm interesting in concretely what is missing or which failure exist?RK3288 Devices
(reboot)
3. ADB by neomode
Originally posted by nutzu View Postdid that but i cant find in the DMESG eth0??,I did all the steps
Because I'm not receive my device until now, it is very difficult to help you, but I will try it.
At my rk3188 this works (because it has root-access)
Code:adb shell dmesg
Code:adb shell dmesg > dmesg.log
RK3288 Devices
Originally posted by no_spam_for_me View PostMaybe it isn't enabled at the settings?
gladly, no problem, it is a pleasure for meRK3288 Devices
Updated FAQ a little about clones and if you should buy a Tronsmart Vega.
There are currently 2738 users online. 1 members and 2737 guests.
