Are they lying?
Tronsmart Vega s89 Standard/Elite FAQ - READ THIS FIRST
Originally posted by spot0915 View PostAre they lying?
EDIT:
OK "... enable passthrough on xbmc ..." hmmm, maybe a problem with your A/V-receiver and the box (incompatible)????RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostNo, really I don't think so, but at the moment I don't know which player he use...?
EDIT:
If I connect my Dune HD Smart Mediaplayer to it via HDMI (same way as the Tronsmart) the AVR shows DTS HD MA when the audio track of the movie is a DTS HD MA track, it also shows other audio tracks correct (like movies with DD, DTS or DD True HD).
Connected to the Tronsmart it only shows "DD" and "DTS" tracks correct, as soon as I play a DTS HD MA Track, the Receiver shows "ES Discrete" (whatever that means)....
Originally posted by spot0915 View Post... as soon as I play a DTS HD MA Track, the Receiver shows "ES Discrete" (whatever that means)....
=> maybe 6.1
I think that's maybe the problem...
EDIT
wiki say it is 6.1...
RK3288 Devices
Originally posted by no_spam_for_me View Postsometimes google is really helpful
=> maybe 6.1
EDIT
http://de.wikipedia.org/wiki/DTS-ES_Discrete_6.1
The same file with the same audiotrack played by the Dune Smart HD is recognised by the AVR as DTS HD MA. That´s what the track is.
Originally posted by noderat View Post- [*=left]
- [*=left]NEW You can follow these instructions to make your Vega IR receiver work for any remote. This is very, very handy as I like to have my air mouse separate from my media center remote
[*=left]
I see no link
thx a lot
- [*=left]
How Can i install XBMC 13.1 “Gotham”
I download the app from XBMC site but when I try to install it, I got can’t open zip file.
I downloaded the ARM app. I tried the X86 also with the same issue.
I want to install it because the current one i have from the Forum have some issues.
I suspect it’s stuck my devise.
I can’t also to set the PVR for Free TV channels and when I tryi to connect to my Net computer for Movies display the XBMC shout down.
thanks.
Originally posted by korenspeed View PostI download the app from XBMC site but when I try to install it, I got can’t open zip file.
thanks.
e.g. http://mirrors.xbmc.org/releases/and...rmeabi-v7a.apk
or
Originally posted by Lokie View PostYou are downloading wrong file. Suppose to be *.apk.
or
http://mirrors.xbmc.org/nightlies/an...rmeabi-v7a.apk
any idea?
i already installed the last XBMC that published in this site.need to uninstall it first?I dont want to delete all the setting i already done
Originally posted by korenspeed View PostI still get the same error: "Cant open file"
any idea?
You can download a XBMC backup plugin (programs) that will backup your db etc.
Your error seems like some other problem - a currupted apk maybe? Just try to re-download
a few possible things could be causing this. First you don't have "package installer" as your default installer not "verify and install apps". Secondy under settings uncheck verify installed apps under security settings and also allow "unknown sources" in developer options. And lastly this can happen when you download from the non stock browser. To fix this go into your file manager (prefferably es file explorer) and find your download folder and click on the downloaded apk file.@µ$ł!Ω
There are currently 4132 users online. 0 members and 4132 guests.
