Tronsmart Vega s89 Standard/Elite FAQ - READ THIS FIRST
    Originally posted by kikikaka View Post
    I have similiar question in addition to above..
    When I put the device to standby (by using the remote control red power button), it goes to standby with Red LED . I can switch it on again by pressing the remote control power button.
    However, if the device ocassionally flash blue light for a few seconds during standby, once this happened, I no longer can wake up the device by using the remote control. I have to press the main power button at the back of the box to wake it up.
    I am using the latest 102k firmware. Anybody have similar problem ?
    Thanks.
    Yea this is very common. It because the unit wakes up to do somthing (on a timer). I suspect its because its trying to sync. Disable the sync of google account and see if it stil does it? PM me if it works (the flashing led prob).
    Regarding the freeze while sleeping - this is also very common. There is a solution in the meantime that seems to work. Enable debugging and select the Screen always on setting. (See the thread one level back)
      Re: Tronsmart Vega s89 Standard/Elite FAQ - READ THIS FIRST
      Originally posted by florian83260 View Post
      There is an air mouse with the Vega S89 in the box ? Thanks
      Envoyé de mon GT-N7100 en utilisant Tapatalk
      No there is no included air mouse in the Vega.
      Sent from my mobile device. Please excuse any typos.
      Only after you've donated to Finless and Neomode are you allowed to donate here.
        Not sure if it has already been requested, but can the OP update the first post to include the 89-H model and it's compatibility (if so ) with the other model's firmwares...
        Sent from my Commodore 64 using Geos
        My devices:
        Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
        Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
        Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
        HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
          does anyone know if the s89H has the hdmi problem? or is it just the regular s89? thanks
            device reboots when playing
            when playing asphalt 8 the device (elite version) reboots after few minutes of racing. it's possible that the issue is related to 1.2 ROM version itself or it's a hardware fault? Can someone test it please?
            Tronsmart s89 Elite - Finless 2.1 ROM
              Toothpick query
              Nubie - not wanting to brick my S89 on first attempt to upgrade firmware;
              so - using the SD card method, at what stage do I remove the toothpick from the reset-hole?
                With the USB burning tool running, remove it once you see it detect the device. Its in chinese but you should see it doing someting
                  Pity he said with the SD Card
                  Remove it once you see the initial graphics on the screen, you should then see the android guy on his side 20 seconds or so later.
                    Oh yea sorry... dangerous method. But its impossible to hard brick. I had to resort to bootable SDcard & pin shorting once when I buggered my booltloader & recovery.
                      aye me too, was it my "how to" that got you out of it.
                      Scarey shit that one.
                        Yea, I followed your thread fervently until you guys eventually got it unbricked. The whole recovery is still not very precise with the tool bombing out during boot flashing?
                        (I might have purposely bricked mine lol )
                          Toothpick query
                          Thanks, guys - I'm glad I asked!
                            Originally posted by noderat View Post
                            How do I get 5.1 Surround Sound audio?
                            • [*=left]
                              • [*=left]Navigate to XBMC Settings.
                                [*=left]Navigate to System.
                                [*=left]Change your Settings Level to Expert.
                                [*=left]Navigate to Audio output.
                                [*=left]Set Number of Channels to 5.1
                                [*=left]Set Keep audio device alive as you like. (This will keep your AVR from turning on and off when there is no sound playing in XBMC.
                                [*=left]Make sure Enable passthrough is selected.
                                [*=left]Enable Dolby Digital (AC3) capable receiver
                                [*=left]Enable DTS capable receiver.
                                [*=left]Exit out of settings and enjoy your 5.1 surround sound!
                              [*=left]
                            I cant get it to pass through DTS and only get hissing sound when I enable dts capable receiver
                            mine is on finless 1.6 with xbmc-20140427-2372235-Gotham-armeabi-v7a-Tronsmart
                            any idea how to get dts pass through ?
                            Proud xbmp>xbmc>kodi user since early days of 1st gen xbox
                            XBMC on :
                            Tronsmart S89 Quad Core - Openelec
                            Atv1 + Crystall HD - Crystalbuntu
                            Raspberry Pi - Openelec
                            Xios DS - Linux the-hydra
                            1st gen xbox, JB Atv2, Ouya, ...
                              Originally posted by papampi View Post
                              [/LIST]I cant get it to pass through DTS and only get hissing sound when I enable dts capable receiver
                              Did you change settings in Vega firmware from pcm to hdmi or spdif?
                              I hope you have fun with my english writing!
                              Now Draco Meta...coming from Vega S89-H, wdtvhd 1, xtreamer 1, zotac ion, raspi and some android smartphone skills
                                sure i did
                                XBMC on :
