Minix X5 4.2.2 ROM with HLS streaming
    This rom is based on the X7 mini stock 011.
    I used the HLS patch from the HardwareGuru 5 roms.
    The kernel used is from the X5 stock rom (006). Also stock boot.img, recovery.img and misc.img from stock are used.
    I have tested the rom myself and all is working properly.
    The result is a very stable rom! (haven't had any crashes so far. Antutu score 13732).
    The "rkxx-remotectl.kl" is updated and support for xbox360 controllers is included. Also Airpin Pro 2.3.5 is in the rom.
    The rom can be flashed with the flash tool included in the zip.
    So if you're looking for a rom that support HLS/Smoothstreaming (used for many live streaming apps) why not try this rom. Or if you want a rom that has working miracast support.
    INSTALL NOTES
    After installation wait for about 5 minutes so that airpin can be installed.
    Have fun with it!
    Credits for the rom base go to Minix and Finless.
    Credits for enabling HLS/Smoothstreaming go to HardwareGuru.
    Credits for patching libmedia.so and enabling DD5.1/DTS passthrough go to Stafstrom.
    X5_4.2.2_HLS_720p_v1.9
    X5_MINI_4.2.2_HLS_720p_v1.2
    XBMC FOR MINIX (GOTHAM)
    WoW! Amazing job Karel. Thank you
      Is this rom with 1080 kernel ?
        720p stock (4.2.2_006) kernel, but you can replaced it with the 1080 stock kernel if you like.
        Sent from my iPad using Tapatalk HD
          boot to recovery
          just installed.
          it does not boot normally.
          just the android system recovery (3e)
          before I had Finless 1.2b ( is that a problem?
            I was about to install this rom, I come from finless 1.3 so I'm just wondering the same as kaher.
            Thanks for any information on this.
            Originally posted by kaher View Post
            just installed.
              Same here, only booting to recovery.
                Try this one (I have changed stock recovery to CWM recovery) DOWNLOAD
                Please let me know if it works!
                  Nope, no difference. (exept a newer version of cwm)...
                    Ok, lets try again. I have made a dump of my X5 (boot.img, kernel.img, recovery.img using the RK 2.1 tool), which you can flash with the Finless flasher tool.
                    I also dumped system.img and added the newest XBMCZ with passthrough and the latest Airpin Pro 2.3.5. I have bootloader 1.34 installed (that was included in the latest minix stock rom version 006). So if you have another bootloader you have to flash the new bootloader (included in the package). Also I recommend to first erase NAND and then flash the .img files.
                    Please let me know if it works.
                    DOWNLOAD
                      OK, should I flash with batch tool or Fineless?
                      Where can I see which version I have on my bootloader?
                        The tool is included in the download (Finless). As far as I know you can't check the current version of the bootloader.
                          OK! First flash nand, then flash bootloader, then flash rom?
                            When opening the flash tool first click on Erase NAND, then select the bootloader file and check the box, then flash all including loader and all .img and parameter files.
                            Then after reboot wait for about 10 minutes (so that the added xbmc and airpin can be installed)
                              Now it seams to work! Havent tested it, but it starts and lookes good! BIG THANKS 4 your help!!!
