Verstuurd vanaf mijn ME173X met Tapatalk
Minix X5 4.2.2 ROM with HLS streaming
Originally posted by KAR View PostDo you Think it will work if i extract the kernel from the last stock fw from g4 ?
(If wifi doesn't work then use the "\system\lib\modules" from the G4 stock rom.)
Re: Minix X5 4.2.2 ROM with HLS streaming
Originally posted by karel View PostI think so. You should try it. If it doesn't work then just flash back to stock.
Can you make an img for the g4 108a and108c as I know man users anna have it ?
Thx again
Thx again
Originally posted by karel View PostUnpack the new G4 stock rom and use my system.img from the zip in the first post. Erase NAND and flash all with the finless tool. Let me know the result!
Originally posted by KAR View PostHi Karel,
Using the img file is fails it keeps strating the recovery menu. Trying using finless prog now.
Regards
Kar
Did it work with the finless flash tool?
Originally posted by karel View PostThanks for the feedback. I will try to fix the single .img file. (Probably increase the size of the system.img part)
Kar
Originally posted by KAR View PostSame issue karel keeps starting with recovery menu
LINK
Originally posted by karel View PostI made a new single .img file you can flash with the rockchip batchtool. This one should work! (I increased the system.img file so it matches the parameter file without any gaps. Probably the too small system.img caused the "reboot to recovery" issue with previous builds)
LINK
KAR
Originally posted by KAR View PostSamen issue karel...again recovery menu
Thx
Kar
I think I need to learn a little bit more about how to package a ROM. Later today I will post a file with a workaround (installing HWG_b02 and then flash over the system.img with the parameter file from the HWG rom).
@HardwareGuru, how do you make the rom to flash (so that it doesn't boot into recovery?)
Originally posted by karel View PostYes, I just removed the download links from the first post.
Ok Thx.. , the finless method works as well so happy to try once available.
In the meantime install the GURU version? Or wait ?
KAR
When your parameter file is not correct one partition will overlap/overwrite the other, so make sure you have the correct hex size values in there to match your .img sizes.
It is size@offset in hex decimals dword /512 bits. ( hard to explain lol )
If you use my original parameter file from my rom it should work ( if the system.img is about the same )
Try removing all apps from cuser and buidl the rom, this way you will probably not go over the set size in the parameter file.
The only thing then is to install the apps by hand ( Xbmc etc.. )
Mostly i put an extra 50-100mb to the system so i have space to work in without calculating all the hex values for each build
There are currently 1701 users online. 0 members and 1701 guests.
