Minix X5 4.2.2 ROM with HLS streaming
Originally posted by scooter2014 View Postok ill test both mini and x5 tonight, for the mini did you use the last released kernel for 1080p?
Hey karel, after firmware download and formatting /data, /cache, mounting sdcard and rooting, system always boots into recovery...
I restart it and it keeps booting to recovery.
I've tried to flash both 720 and 1080 kernel versions...
It's a no go for me...Plasma: Panasonic TX-55ST60E
HTPC: LC-Power 1320mi :: Sapphire PURE WHITE Fusion E350 :: 4GB DDR3 :: SSD Corsair Nova 2 [SO] :: 4TB [Storage] || Android PC: Minix X5
powered by Win7 :: XBMC Gotham :: SABnzbd :: CouchPotato :: SickBeard
Originally posted by redglory View PostHey karel, after firmware download and formatting /data, /cache, mounting sdcard and rooting, system always boots into recovery...
Does scooter2014 have any problems?
Downloading...
I'll report after finished!
Neither 1080p or 720p... each one reboot into recovery after formatting /data and /cache and booting...
Back to kasty... againLast edited by redglory; 27 May 2014, 20:26.Plasma: Panasonic TX-55ST60E
Read the test notes thats normal thing just exit and reboot .! Read my test notes will help you. Post 37.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Of course i tested rebooting after recovery, several times. It was a no go for me. Have you tested new roms flashing?
Strange thing is that i was expecting cwm and got stock recovery? Using both methods...
sent from my Nexus⁴Plasma: Panasonic TX-55ST60E
Re: Minix X5 4.2.2 ROM with HLS streaming
Originally posted by redglory View PostOf course i tested rebooting after recovery, several times. It was a no go for me. Have you tested new roms flashing?
sent from my Nexus⁴
In my case after formatting the nand and flashing the firmware it starts recovery to format data and cache partitions. After that it starts the ROM and installs xbmc and airpin.
Mine restarts to stock recovery after formatting /data and /cache and stays there... Might be a parameter issue?
Originally posted by redglory View PostMine restarts to stock recovery after formatting /data and /cache and stays there... Might be a parameter issue?
sent from my Nexus⁴
The parameter files in the package are from the latest stock roms.
Option 2: You could try to flash the latest stock rom (if that doesn't work (read: reboot to recovery) then you and I know it is not an issue I created).
Option 3: As I read on freaktab it is best to ERASE the nand FIRST with the parameter file of the rom that is/was installed. (In your case Kasty rom). There are differences between Kasty and Stock parameter.
Kasty: 0x00140000@0x0091c000(system),-@0x00a5c000(user)
Stock: 0x00100000@0x0091C000(system),-@0x00A3C000(user)
After Erase NAND with the Kasty parameter file. Then select the X5 stock parameter file and flash without erasing again. It could now be the case that some of the system and user partition isn't erased correctly.
Option 4: If the stock rom does work then after installation you only have to flash the system.img using the finless flash tool with the right parameter file.
Option 5: Walk through these steps
I would start with option 3 and if that doesn't work go for option 2 and 4.Last edited by karel; 28 May 2014, 19:28.
Option 2 went ok. I've flashed official stock rom and booted ok.
Than went to option 4 and used your parameter )which is exactly the stock rom parameter) and flashed system_1080p.img.
Got same problem... only boot to recovery...
Tried system_720p.img same thing.
Then i just unpacked stock rom, used 1.22 loader instead on 1.34 and chose every file except system.
I erased nand, flashed system_1080p.img and voila. It booted ok!
1st problem, my launcher was all messed up. Bar on the right side vertically, search on the left... all messed up! I let it install everything and booted. Same thing...
Finally i chose system_720p.img and flashed and all went as expected...
now my only problem... i can pair my headset,it says paired but i don't get to connect it... I can't access its options (phone audio and media audio won't show) because it isn't connected...
So long story short... I got to flash this rom but same BT headset problems... Getting tired...
What were the files patched in this system.img? Can i try to patch original rom and see if i get BT to work?
ThanksPlasma: Panasonic TX-55ST60E
There are currently 1958 users online. 0 members and 1958 guests.
