I updated the first post with the download link and some extra info.
Minix X5 4.2.2 ROM with HLS streaming
Does wireless vga to rca work?
I am trying to setup a VGA connection at a podium (for people to give presentations)
to display on an HDTV mounted on the wall. Was going to put in a wireless VGA to
Component, or VGA to VGA device.
I am debating on whether to use wireless or get a VGA to CAT5 converter for each end,
and just pull a CAT5 wire between the podium and the HDTV.
Originally posted by ben_reddik View PostHi!
I just joined and found this fine thread.
What will this solution do to other providers that don't tolerate rooting? Like HBO Nordic, will I still be able to use my subscription there, or will I have a problem?
Thank you for what looks like a good job :-)
Put it on recovery.
Select every file accondingly and tick Loader.
Erase nand and flash rom
Enviado do meu Nexus 4 através de TapatalkPlasma: Panasonic TX-55ST60E
HTPC: LC-Power 1320mi :: Sapphire PURE WHITE Fusion E350 :: 4GB DDR3 :: SSD Corsair Nova 2 [SO] :: 4TB [Storage] || Android PC: Minix X5
powered by Win7 :: XBMC Gotham :: SABnzbd :: CouchPotato :: SickBeard
i finally figured it out......wow my machine was never this fast before. thanks......but i did have to hunt around for add on's like the mash up and one channel.......i use to have a problem with my key board being off a little with the curser but not anymore......i'm looking forward to playing with it again
I'm having trouble using my BT headset (Kinivo BTH220).
I can sync it with BT but no sound...
Has anyone had this problem?!
ThanksPlasma: Panasonic TX-55ST60E
Please fix download link.
Originally posted by karel View PostMinix X5 4.2.2 stock roms don't support the HLS/Smooth streaming. On the X7 forum I noticed that HardwareGuru made a X7 4.2.2 rom which enabled HLS/smoothstreaming on many Live streaming apps.
Then I thought lets combine the X5_4.2.2_006 stock kernel with the system.img of the X7 HWG Beta 04a.Rev2 rom.
The result is a very stable rom! (haven't had any crashes so far).
I added an updated "rkxx-remotectl.kl" and support for xbox360 controllers. Next to that I added XBMC Gotham 13.0 rev2 which enables DD5.1 and DTS passthrough. And I updated the Airpin Pro to version 2.3.5.
The rom must be flashed with the Finless Flash Tool.
So if you're looking for a rom that support HLS/Smoothstreaming (used for many live streaming apps) why not try this rom.
INSTALL NOTES
When opening the flash tool first click on Erase NAND, then select the bootloader file and check the box, then flash all (including loader and all .img and parameter files).
Then after reboot wait for about 10 minutes (so that the added xbmc and airpin can be installed)
Have fun with it!
Credits for enabling HLS/Smoothstreaming and the system.img go to HardwareGuru.
Credits for patching libmedia.so and enabling DD5.1/DTS passthrough go to Stafstrom.
Credits for XBMC Gotham 13.0 rev2 go to the XBMC team and jmcm66 for compiling XBMC.
DOWNLOAD
Karel do you use bt headset with this rom? I can pair my headaet but no sound comes from it. On previous rom all good.
Re: Minix X5 4.2.2 ROM with HLS streaming
Originally posted by redglory View PostKarel do you use bt headset with this rom? I can pair my headaet but no sound comes from it. On previous rom all good.
Could be a libmedia.so hack issue.
There are currently 4605 users online. 0 members and 4605 guests.
