I don't know what files were patched, because the X7 rom was made by HardwareGure. I (and also some others) have asked HardwareGuru what files needed to be patched to enable HLS, but he never gave any answers. It could also be that he used the minix stock X7 6c rom (also enabling HLS) that was a 4.2.2 firmware with some 4.1.1 code patches. It could also be that the bluetooth device you have isn't supported and the bluetooth device scooter2014 uses is supported in this rom.
Minix X5 4.2.2 ROM with HLS streaming
Yup it's very strange....
Nevertheless my BT headset is a must have so i'm stuck to kasty's.
Thanks!
sent from my Nexus⁴Plasma: Panasonic TX-55ST60E
HTPC: LC-Power 1320mi :: Sapphire PURE WHITE Fusion E350 :: 4GB DDR3 :: SSD Corsair Nova 2 [SO] :: 4TB [Storage] || Android PC: Minix X5
powered by Win7 :: XBMC Gotham :: SABnzbd :: CouchPotato :: SickBeard
I've read an tried everything in this topic, but no succes..
If using the rom-flashtool 137, the Minix Neo x5 only starts in recoverymode. tried 720 and 1080.
Then read the comment of Redglory, but i'm missing something?
- flashed the original with rockchip batch tool v1.7 (system starts ok, but still no working netflix)
- started finless flashtool
- erased nand
- unchecked everything but the system.img and selected system_720p
-flashed
but now the system won't start at all?
What am i doing wrong here? Just want to have hls working so netflix wil start a movie...
back tot stock-rom, my kids are getting unpatient.. icefilms on xbmc works fine...
thnks in advance
You can:
1. unpack stock rom in order to get parameter, loader_V1.22, boot.img, kernel.img, recovery.img, misc.img
2. choose everything from unpacked Stock ROM on finless flash tool, apart from the system.img
3. select system_720p.img or system_1080p.img from this HLS ROM (1080p for me didn't work as expected...).
4. Erase nand.
5. flash everything
I hope this works for youPlasma: Panasonic TX-55ST60E
Regarding my problem, I'm going to try something like this
And also other sound/bluetooth apps...
If everything fails I'll have to stay with Kasty's and its random reboots (I think it has something to do with my Mele F10 air mouse conflicting with minix...)Plasma: Panasonic TX-55ST60E
Originally posted by redglory View PostHi,
You can:
4. Erase nand.
5. flash everything
The file X5.4.2.2_20140306.img, that i've downloaded from http://www.minix.com.hk/Support.htm cant be unpacked? tryed isobuster, utraiso... even renaming it to iso, but no succes... any suggestions how to obtain the img's en parameter files?
You can:
4. Erase nand.
5. flash everything
The only thing changed is renaming the bootloader. So I changed that name back to V1.22 and will repackage and upload all tomorrow. Also I remove the system_1080p.img (with densitity set to 240) because it doesn't show right.
Does the system_720p.img display correctly using the 1080p kernel?
I will also remove the one in all .img files, because people are having trouble with it booting to recovery everytime.
karel i can flash with all files from stock except system. I only had problems using system1080p.img my launcher was all mixed up.
I use 720p and all good. My problems now are headset bt and not being able to connect (can't see headset options)Plasma: Panasonic TX-55ST60E
Re: Minix X5 4.2.2 ROM with HLS streaming
Originally posted by redglory View Postkarel i can flash with all files from stock except system. I only had problems using system1080p.img my launcher was all mixed up.
down loaded pack mini doesnt boot unly back to recovery 720-1080 same results noticed changed cwm maybe ? i try mini 720 package now.
black screen no post on mini build?
damn lol,Last edited by scooter2014; 30 May 2014, 04:43.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
For now I also removed the big package, because some were having issues (reboot to recovery) with it.
Flashed complete rom .img same result. Back to recovery...
Then flashed with finless flash tool and chose everything from stock and your system.img and went ok.
I can't understand why but my headset doesn't even connect... And i did the same thing you did. Grabbed stock lib/modules and mounted system and overwrite everything on previous flash and at least i could connect headset but still no sound...
Getting sick of this... *sigh*
Karel,
tested yout version 0.9. Same issues as Redglory overhere.... booted at recovery again... sorry...
For an extra test, i''ve downloaded the 720p rom from kasty (found it on artablet.com). Works fine, boot ok, but still no Netflix.
Redglory, how did you manage to combine? Cant unpack the update.img, so i have to flash with the rockchip-tool.
Can you tell me that if you use every img from kasty 720p, an use the system.img from Karel, that Netflix works fine (as in starts a movie in stead of loading all the time)?
And if so, how do i unpack the img from kasty?
thnks in advance..
There are currently 1983 users online. 0 members and 1983 guests.
