Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
    Originally posted by oman View Post
    Tomorrow I will upload the ROM.
    Yes please
    Also if someone wants to dump the ROM the 2.3 tool will do it as I explain here:
      If no one else beats me to it I'll do this when I get back this evening, needs to be done, want to apply the ota but not without a backup
        Remember there are new partitions that need to be dumped. You will see them when you pull the parameter file with the tool. resource.img is a new one. Also uboot.img is a new one but on my HPH box this was blank (all 0's). But dump it anyway just in case.
        Of note: these need to be dumped:
        boot.img
        kernel.img
        misc.img
        recovery.img
        resource.img
        system.img
        uboot.img but probably not needed.
          Good shout, will get this done this evening. Cheers Bob
            For some reason, I am having difficulty getting this box connected to the Androidtool V.2.3. I have installed the driver package Release driver assistant from Oman's posting, at least I think it installed. I connect the OTG port to my usb port on my computer. I depress the reset button inside the AV hole with a tooth pick, but it still shows no devices found. I have done this many times with my RK 3188 boxes. I am sure my problem is that the driver is not installing correctly. Any advice you can offer me?
            thanks
              I've known your problem,will discuss it with my coworkers tomorrow..
              But it's so ridiculous,56€?much more than the price 50$,Could you tell me why so high?
              I don't know why the price is so high. I am very disappointed with the Greek government. Anyways discuss it with your coworkers and tell me your decision ok? I am very sorry for the inconvenience
                Re: Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
                thanks
                Try installing quick boot from play store and rebooting to recovery/boot loader from there
                  I guess I don't understand your reply. I have removed the box from my tv and trying to connect the box to my Windows 7 64 bit computer using the otg cable, so I can dump my rom. Do you mean I have to have my box connected to the tv inorder to connect to my computer?
                  thanks for your reply
                    Have box connected to TV reboot to recovery then plug into your computer via otg cable
                      Ok, thanks for the clarification.
                        ... I have done this many times with my RK 3188 boxes. I am sure my problem is that the driver is not installing correctly. ...
                        have you checked with a rk3188 device after the driver update?
                        FYI if you already have the 3188 drivers installed these work with the 3288 devices just fine. I just got a 3288 box and everything works like 3188 including the flash tools.
                        RK3288 Devices
                        - Overview BOX (LINK !)
                          That was my thoughts, just to verify that the drivers are working with my other RK3188 box. Also, Finless said that the batch tool for rk3188 will work for the rk3288.
                          thanks
                          Update, connected my rk3188 box (TV01) to my computer and opened rockchip batch tool ver. 1.7 and depressed the reset button. Box connected correctly. Connected R89 box with otg port and depressed the reset button located inside the av hole. rockchip batch tool ver. 1.7 could not find device. I am assuming the reset button is inside the AV hole, since I can feel the "click".
                            As far as i know in cases like this one the greek custom office charge 5-10 euros (usually 5) as taxes the rest is clearence agent fee for DHL but in case you want to be 100% sure <<convict>> can contact DHL office in athens airport (tel 210 4062700) and ask them what exactly they charge sorry for the greek language
                            @ convict
                            Επικοινωνησε με την DHL και θα δεις οτι μαλλον εχω δικαιο, σε δικη μου περιπτωση οταν τους ειπα οτι δεν θελω να εκτελωνησουν εναν δουιφορικο δεκτη απο κινα αξιας 78 ευρω αλλα θα πηγαινε να τον εκτελωνισει ο γιος μου τοτε μου ζητησανε εαν θυμαμαι καλα 86 ευρω για να παραδωσουνε τον δεκτη και τα εγγραφα συνοδειας στο τελωνειο τα οποια τα πληρωσα ετσι για ενα πεισμα και απο τοτε δεν ξαναχρησιμοποιησα την εταιρεια αυτη. (εαν θελεις σε παρακαλω μεταφρασε τα ελληνικα στα αγγλικα για να μην εχω καποιο προβλημα επειδη εγραψα στ ελληνικα)
                              thanks
                              go to settings -USB - and enable Connect to PC...
                                thanks
                                Sorry, I can't help at the moment because my device flys around at Hong Kong ...
                                RK3288 Devices
