Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
I had the problem after applying the OTA and again after flashing the full (updated) ROM through the flash tool. The only way to get the box working again was to go back to stock. The factory reset was just something I tried, not really related to the problem. But I am somewhat relieved to hear I'm not the only one who has seen this weird behaviour
Sv: Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
Originally posted by NikAmi View PostThe packaging indicated that there should be one so I don't know if they just forgot to put it in or what. When I do my testing, it will be limited to what I can do with a keyboard and mouse.
Unboxing: http://youtu.be/zSKAu7IEj4M
I really hope that they will send you the missing remote control!
I haven't got one either but Tronsmart S89 Remote works or If you got Harmony universal Remote you can load Tronsmart vega s89 profile to your harmony remote thats what I've done...
Originally posted by TMx View PostAs far as I know No IR remote posted to the testers ...
Originally posted by Finless View PostI have several IR remotes that work! It's just a matter of using the correct remote.conf file.
copying remote.conf to system/etc helps but this time at this location there was no remote.conf to replace and copying the csm8 remote.conf to that directory didnt helped(ticked all permissions)
Originally posted by oman View PostYes,you are right..
Dear
no_spam_for_me ,bloodgnome,LawlessPPC,4WheelSpyder,ssspacman ,ademturk ,Arbelzapf ,talas ,NikAmi ,goldenrod ,TMx ,sync ,sweup,Smokez,ENDRJUPL,clarkss12,Catadarius,tltest er,convict ,mmind00
Have you all got the toy for play?).
More testing in the following days.
PS.:
I hate DHL
R89 as a PVR
One of my main objectives with these boxes is to use them as an inexpensive PVR (personal video recorder) using the gear that I already have. This box is getting soooooo close to matching a stand alone DVR. By programming the buttons from the standard IR remote to my Harmony universal remote, I can use this PVR just like my stand alone DVR. And the Guide is the best I have ever seen or used.
Not to bore you too much, but I just made a YouTube video showing my PVR. I have other videos showing the same thing, but this box is awesome for my purposes.
Originally posted by clarkss12 View PostOne of my main objectives with these boxes is to use them as an inexpensive PVR (personal video recorder) using the gear that I already have. This box is getting soooooo close to matching a stand alone DVR. By programming the buttons from the standard IR remote to my Harmony universal remote, I can use this PVR just like my stand alone DVR. And the Guide is the best I have ever seen or used.
http://youtu.be/-cfuE41iFF0
Originally posted by 4WheelSpyder View PostWOW Amazing! Do you have a TV tuner interfaced as well! We should maybe create a separate thread tilted R89 PVRMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by sweup View PostDid a quick unboxing and sneak peak video
http://youtu.be/LiszOQtrjsIMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by TMx View Postthats exactly what I do for CSM8 box when I install other s802 devices FWs ...
http://youtu.be/-cfuE41iFF0Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
There are currently 1647 users online. 1 members and 1646 guests.
