Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
    AW: Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
    I can tell you he is VERY open to the developers here!
    If you look around you see he is supporting us. You testers got the hardware first to start, then the Dev's here once things get going. Trust there will be lots of activity from Dev's for the Beelink and Tronsmart devices. Oman has been great working with us and sharing with us!
    Bob, i know oman is helpfull and open to the comunity, my question was more about how open the source code will be, will the comunity be able to port future versions of android even if development from beelink has seized in favour of newer devices...?
      Excellent. Oman has really shown the right way to go
        Sure Bob, Oman & Beelink have been quite right with their strategy to develop and evolve this RK3288 device, but however I would like to request to Oman and their design enginneers to change that external case with that very unconvenient shape of some kind of "pyramid" for just simple conventional one (square or rectangle); to diferentiate the device thay had done already good on the base of quality build, it´s not necessary to re-invent the wheel with those "uncoventional aesthetichs designs" to say the least; it´s a matter of hardware quality (pcb + CPU+GPU+ WiFi/BT chip, and other electronics components) and a great and solid Android Firmwares, that´s all, not those strange case/housing designs. It´s an opinion; I would like to go with the device as soon be going to the mass market.
          Piramid? ? U mm mm no thanks.
          Oman had design talks you missed it 😉 Moving on
            Oman had design talks you missed it  Moving on
            Nope, I did not missed that discussion; they had just added vent holes, but still preserving that strange shape (like a "piramid" or something like that), why? what advantage you get with that shape, it´s just difficult to stack up; keep it simple, square or rectangle with vent hole and rubber feet, that it´s!; they can succeed on sales with PCB quality, build quality not need to invent those ugly and strange shape!. Just an opinion.
              Sales and Marketing Difference, think its called
                As I scan my desk and entertainment center, I have all sorts of "strange" or "unconventional shapes". Yes, at first, I wanted to have all my devices square or rectangular so the could be "stacked", but after awhile, I adapted. I like the different shapes, even though sometimes I have a difficult time finding an eye pleasing way to place them. I thought I would hate that round S89h, but now I have become to like that shape. Also, I have seen people place items on the devices that "need" to breathe. I have even seen people with A/V receivers that had the entire top covered with items, completely blocking the vent holes. A lot of people have no idea how much damage they are causing to their electronics by "stacking" them. I cringe when I see vent holes blocked by dust, or anything else that blocks the vent holes. So, I would hope that when the designers create these shapes they are taking into consideration of ventilation.
                  Originally posted by convict View Post
                  Hi guys I don't know where to post this so I will post it here. Location services are not available on the r89. Does anyone else have the same problem? Thanks
                  Yes, same problem here.
                    I like the design! You want to know why? Because there is enough space inside the case to better handle the temperature than this flat tiny cases... (btw: also more space for own heatsink mods)
                    BTW: stack up isn't a real good idea because of temperature (also not with vent holes)... but clarkss12 described it very well
                    RK3288 Devices
                    - Overview BOX (LINK !)
                      => http://www.freaktab.com/showthread.p...-feedback-here
                      RK3288 Devices
                        Well, you are right because I had said "stack", which it´s only one possibility that,anyway, I do not use at all, but IMHO that shape used by beelink requires more vertical space on TV/video table to allocate this TV box, which for me it´s a real concern on some "home setups"; all of these TV boxes are fan-less, even this strange form factor used by beelink; none of the classic - conventional shaped TV boxes, branded by a serious manufacturer like apple, amazon, and going to chinese market just to mention one more, Minix, they are not burning the device because of the square or rectangle form shape, even overclocking to the maximum a Minix X7 with classic square form shape, "zero thermal" problems; so, may be it´s a matter of personal preferences, but technically in this case, I can not see the justification; and it´s controversial from the stand point of market approach. Which actually makes difference is hardware build quality and confiability, durability combined with a solid OS/Firmware, not the external case; not need to going to these extreme form shapes (same situation for that round shape mentioned by clark, quite bizarre for devices like these TV boxes, but less worse because at least the bottom and top of the box are parallel).
                          The case design has reports of out of alignment issues with slots and ports, bottom pads being too short to keep the unit up high enough off the surface for proper airflow, and the bottom section becoming a closed thermal box allowing heat build-up. I certainly do hope these issues are being noted by Oman and modifications will be made for the final retail product. Fanless devices need proper thermal airflow design, large high quality heat sinks fastened properly with quality heat sink paste to allow the unit to handle the worst case scenario for it's intended use such as high end game playing for hours.
                            Yes, you are right, a little bit more space under the device will be nice (but, come on, if I want and if I mean I must do so, no problem to place a little bit bigger feet by my self )...
                            BTW: I don't have the same problems to plug the cables to the ports (normally I do it once and never again ) but the SD Card slot is a "fun generating" part (some short stress moments "where is my SD Card" )...
                            RK3288 Devices
                              Originally posted by almirus View Post
                              hi. is there support full 3d via HDMI (b3d iso)?
                              Yes!
                              Rockchip just released the patch for the 3D blue ray
                                Originally posted by Stuv View Post
                                Yes!
                                Where is the best place to follow news from RK regarding patches/updates around RK3288?
                                Beelink R89
                                Pioneer SC-2022
                                Samsung 55" LED 2012
                                Previous:
                                Minix X8-H
                                Minix X5
                                Logitech Revue
