It has come to my attention my BETA1 ROM was made from an older 7b G2 Capacitive ROM dump dated Sept 2011. Arnova has a newer ROM on thier web site dated Dec 2011. Some recent 7b G2's had sound issues with the older BETA 1 ROM.
So this is BETA test 3.
It is created using the latest Arnova 7b G2 ROM from thier wbe site.
BETA 3 also fixes the battery status icon or anywhere else the bettery percent is shown.
Below is the link for the new BETA 3 ROM. I am leaving the link for the BETA 1 ROM incase some have issues and need it.
_________________________________________
OK folks.... with the success of the 7G2 2.1 Gingercomb ROM "BETA" test, I am now going into BETA TEST 1 for the Arnova 7bG2 "capacitive" Gingercomb 2.1 CWM.
THIS ONLY for the 7bG2 "Capacitive Scree" tablet!
This is a full 2.1 with ClockWork recovery, debloated, App Injector, etc!
THIS IS A BETA TEST!
I have tested this using my 10G2 kernel. It works as best I can test. I am unsure if the battery icon in the status bar will work. You all well let me know as I may have to tweak it.
PLEASE read the READ ME. You must reboot after first flash in the proper way. After reboot if you get a bunch of errors or force close issues, you rebooted too soon and will need to reflash again.
I have to say after doing the 7G2, the 7's are VERY PICKY about just doing a reset using the pin hole reset! Of course this is NEVER the proper way to shutdown a Android OS. So please be careful and let the system do all it needs to do before you hit that reset pin hole! I always wait for the system to go to sleep on it's own and then hit the reset.
So on with the BEAT testing
Below is my standard talk about 2.1 for all my ROMS.
__________________________________________________ ___________
PLEASE READ the README.TXT for instructions and what this ROM is about!
You can also read about it on the 10G2 here to learn more about it:
http://www.freaktab.com/showthread.p...ersion-2-1-CWM
REMEMBER! Just like most my ROMs that have major changes to it, ERASE IDB and FLASH THE LOADER! Do this before reporting any problems! You can have screwy things happen if you do NOT erase IDB. Loader is also very important!
Now this is a BETA TEST ROM! I cannot fully test everything! So you are CRASH TEST DUMMY'S
When reporting problems please try to be as detailed as possible! If there is no detail to your problem and the steps you took to make the issue happen, I cannot help much. So to help make this ROM better for everyone, please be a good tester and document the issue as best you can!
Also those that know how to use ADB or pull the logcat file, this will help a lot! So if you know how to do this when testing, please supply a logcat dump.
OK on with the ROM.
Here is the download:
BETA 3 ROM using latest Arnova Stock ROM.
ROM -> Arnova 7bG2 Capacitive - "GingerComb" Finless 2.1 CWM - BETA 3 (205 megs)
BETA 1 ROM using an older Arnova Stock ROM.
ROM -> Arnova 7bG2 Capacitive - "GingerComb" Finless 2.1 CWM - BETA 1 (205 megs)
Enjoy and happy testing!
