Arnova 7bG2 Capacitive Finless Bob's "GingerComb" Custom ROM Version 2.1 BETA 3
Yes.... that is the testing i need.
I will fix your battery icon once we know all is working well.
So you have beta 1 kernel.img and beta 3 everything else?
Test away and if all goes OK after a day I will fix the battery icon.
I'm not sure if it's my problem or not, but the shut down function does not work; it just shows the shutting down caption and nothing happens.
Ethernet icon's problem is fixed.
Other than that, I didn't find anything noticeable yet.
Update: Sound works but it's not possible to change notification ringtons, I get FC message.
Sent from my Arnova 7b G2 tablet using Tapatalk 2
Seems the new system is doing something with shutdown. It's not a kernel problem then.
I will look into it but this one may take some time since I cannot test
FYI, you just need to ignore the ethernet icon. I cant get rid of it but trust it is not doing anything since you do not have an ethernet port. I am leaving it in as one day a USB thernet adapter could be used!
ansarijavid, I think I have the shutdown problem fixed
Do you know how to copy files from SDcard into the system at all? Like using ES File explorer?
Or are you a newbee to all that?
Reason I ask is I have a simple file I could give you to test shutdown so you do not have to flash a ROM. But I need to know you know how to do this kind of thing?
Originally posted by ansarijavid View PostDon't know you've noticed or not, I've found a problem with sound, it works but it is not possible to change notifications in the setting or other apps like facebook messenger. I get FC message.
Were you able to adjust volume on the full beta 1? I bet you did not try because you have no sound on beta 1.
The Gingercomb ROM does not have sound control like the Arnova stock ROM. You have to go into settings and sound to adjust the different levels. Try it.
Originally posted by Finless View PostWere you able to adjust volume on the full beta 1? I bet you did not try because you have no sound on beta 1.
There are currently 1623 users online. 2 members and 1621 guests.
