nba game time working on this firmware?
NEW - Minix Neo X7 - Finless 1.9 ROM
Ethernet auto-negotiation issue
Hi Bob,
is there a way to manually set the ethernet speed and duplex??
I have some problems with auto-negotiation, the connection is at the beginning unstable, when it gets stable, works only @ 10 Mbps speed - full duplex.
That's due to my Cisco 10/100/1000 Mbps switch, that the Neo X7 doesn't like I think.
Thx in advance and congratulation for your rom.
problems playing 3d in finless 1.9 rom
Hi all, I just installed this version and add XBMC 3d movies on a NAS and have no synchronization of the images are well reproduced, as if it makes me put the gafas.Mi tubiera tv is 3D and is accessed by the network 3D movies are played well so I think that some of the neo x7 minix. I tried to play the movie from the mxplayer, minix XBMC, spbmc and does not do well either by network or locally. The normal mkv movies work perfect, but I 3D film looks as if you do not have glasses. someone has the same problem or know how I can solution?
Originally posted by jdcolomc View PostHi all, I just installed this version and add XBMC 3d movies on a NAS and have no synchronization of the images are well reproduced, as if it makes me put the gafas.Mi tubiera tv is 3D and is accessed by the network 3D movies are played well so I think that some of the neo x7 minix. I tried to play the movie from the mxplayer, minix XBMC, spbmc and does not do well either by network or locally. The normal mkv movies work perfect, but I 3D film looks as if you do not have glasses. someone has the same problem or know how I can solution?
Re: NEW - Minix Neo X7 - Finless 1.9 ROM
Originally posted by jdcolomc View PostHello everyone,
I have the finless 1.8 and want to upgrade to 1.9 but I can not because the PC now does not recognize my minix. is there anyway to update it otherwise? you can put to install directly from the external sd?
if I upgrade to 1.9 I will be kitkat?
Scribed henceforth from thy G pad.
HLS Streaming patch install failed and same for Deodex patch? Help pls
Hi to you all here!
I am very very new at this only used jailbreakad apple tv 2gen. So I bought the Minix neo X7. My purpose is to use Netflix and and watch movies from my network drive.
I have tried all that it say in the read me text but it dont work. When I try the first options going thrue the boot i cant see the file when I try the second option rename the zip file to update it says install failed. I have only used external sd card and am using SanDisc Ultra II SDHC so I wonder how I use the internal SD or get in the zip files there?
What em I doing wrong
Originally posted by ryadre View Postim having trouble doing the hls patch as well. method one has an error - no MD5 file found and zip signature verification failed
method two - rename to update.zip and when you get to do the update it fails. if you rename it to update without the .zip it doesnt recognise it to give you the prompt to do an update. I also found it had to be on the external sd card, wouldnt do it on the internal sd
any help please? im trying to get ftv add on working along with ontap tv
In normal mode, renaming the archive to "update.zip" (without the brackets obviously), I get the install pop-up. When I click on ok, I receive the invalid file error message. If I rename it to "update", nothing happens.
In recovery mode, the installation of the file labelled "update.zip" produces a failure message indicating that zip could not be verified; md5 not found. Labelled "update", the file could not even be seen.
The same problem occurs with any other "update.zip", at least a couple of files created with Titanium Backup.
Not much going on here at the momentbut I was wondering whether this rom supports cifs etc. I'm trying to use mount manager to mount some shares I have on my seagate NAS. The browse option doesn't really work and I can't get anything working.
Sent from my iPad using Tapatalk HD
Originally posted by Stainy View PostI was wondering whether this rom supports cifs etc. I'm trying to use mount manager to mount some shares I have on my seagate NAS. The browse option doesn't really work and I can't get anything working.
I use Android cifsManager to connect shares on a QNAP NAS.
There are currently 1811 users online. 1 members and 1810 guests.
