Thanks m8 your a genius = bob..
NEW - Minix Neo X7 - Finless 1.9 ROM
Originally posted by ant View PostHey guys, I've done the edit to the tcp.buffersize Bob mentioned. I used the boot1080no_air.img if anyone wants to try it?
I've tried the boot.img and it works on my X7 (doesn't hang or anything) but I don't have the NAS setup to test properly.
Here is the link http://www.mediafire.com/download/2j...1080no_air.img
Hope you don't mind Bob....
Again thanks for helping everyone!
Re: NEW - Minix Neo X7 - Finless 1.9 ROM
Originally posted by Finless View PostDon't mind at all! THANK YOU! You saved me the time. Work was kicking my but so I just did not have time to do this that fast. I was going to do it tonight but now have some time back
Verstuurd vanaf mijn HTC One met Tapatalk
If you only edited init.rc, I'll do it by myself, since my boot is 720p with Airpin.
Originally posted by magno View PostDid you only edit init.rc? Or did you also have to recompile kernels or something like that? I don't really know much about Android kernels, that's why I ask.
If you have problem I'll make u a boot.img tonight. Just remember to reset date counters within boot.img after the edit and sign with rkcrc - kMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
BobI don't know where u find the time?
Anyway many thanks for the great ROM. It's the best JB build I've used on any device.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Ant, if you make all these boots, I will zip them up and put them on the server and add to my post. If your OK.
I will wait till your done and then do it.
Again thanks for helping me out!
Originally posted by ant View PostJust remember to reset date counters within boot.img after the edit and sign with rkcrc - k
EDIT: I didnt reset any counters and the ethernet performance increased anyway:
Originally posted by Finless View PostAnt, if you make all these boots, I will zip them up and put them on the server and add to my post. If your OK.
I'll knock them out later while I'm watching the footy (soccer)
Originally posted by magno View PostWhat is that for? I changed those TCP parameters restoring the defaults, but I don't know if I should do anything else.
EDIT: I didnt reset any counters and the ethernet performance increased anyway:Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by ant View PostHey buddy, I was gonna do the entire set of boot.img's and upload them as a thank you for your continued great works!
If you do the edits on your X7 you don't need to sign or reset the dates. I incorrectly assumed you would do the edits on a pc then flash your modified boot.img.
There are currently 1783 users online. 1 members and 1782 guests.
