First of all great work! This rom really improved my minix enormously.
Everything ready to go from get go, very impressive.
Few minor details, the standard install unchanged gave me a black screen although i do have 1080p Toshiba tv. Having set the 720 rom made it run perfectly, the display option showed 1080p nonetheless which is somewhat confusing.
As for TWRP... how does one operate it? Do i need to buy a wired usb keyboard? If so which one do you suggest?
I tried installing the deodex patch using the suggested rename to update.zip which indeed causes the system to try and load it. However it gives an error message it's not a valid package.
I checked, the zip is intact and without errors.
Which is why i tried TWRP... and got stuck there not being able to operate it.
Thanks for this great piece of work anyroad!
