NEW - Minix Neo X7 - Finless 1.9 ROM
Originally posted by kodikas View Post
Originally posted by bobby55 View PostIs it possible to un-root the Finless 1.9 ROM?
Reason i ask is, I want to use sky go on my minix x7 but I get the following error when running sky go. "sky go is not supported on rooted Android devices"
Originally posted by LCBXX View PostUse the flashing program and untick everything but the Kernel tickbox. Put your the 1704 kernel of your choice in the FinlessROM folder of the flashing program and copy/paste the name of the .img file in the 'Kernel' field of the flasher. Like this:
[ATTACH=CONFIG]6591[/ATTACH]
DO NOT click 'Erase NAND', just click 'Flash ROM' and you are done!
Thanks! It worked!
Originally posted by magno View PostYep, in fact yours is the same way than LCBXX posted, but I didn't realize you replied, sorryMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
I just installed the rom, I'm going to download a couple of apk file from the internet and asks me the sd card, then I went into file explorer and it does not recognize the internal memory, 4GB is available only for the installation of the app. I can't istall anything directly. What can I do?
Originally posted by kianfra86 View PostI just installed the rom, I'm going to download a couple of apk file from the internet and asks me the sd card, then I went into file explorer and it does not recognize the internal memory, 4GB is available only for the installation of the app. I can't istall anything directly. What can I do?
Also, do not have both LAN and WiFi switched on. Switch off the one you are not using.
If the problem still exist do a manual wipe from TWRP.
The 4gb partition for apps is correct. If you require more space for apps flash with a different parameter file.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by ant View PostIf you've only just flashed the ROM and the internal sd card (nand flash) is not mounting try a re - flash.
There are currently 1592 users online. 0 members and 1592 guests.
