NEW - Minix Neo X7 - Finless 1.9 ROM
    Play not working...on some
    I have 7 Minix x7 players. Two are from earlier this year and worked splendidly with the previous ROM on it but not Google Play doesn't load....I just bought 5 additional units which i am having no problem with.
    Do I need to flash the new Minix firmware to these two that Google play aren't working on?
    Thoughts?
    Thanks!
      Thoughts?
      Thanks!
      Nevermind....for some reason....I think that the wrong TIMEZONE was causing the problem.
        anybody knows if finless bob has any plan to migrate his 2.x version for minix?
        this 1.9 is based on 4.2. i'd be interested in a 4.4
        thx
          Does this work with XBMC 13.1/13.2 or can they be installed on this ROM?
          Thanks.
            Are you re-naming the file correctly? You should name it "update" (without " ") only! Not update.zip or anything else by mistake.
            Hope you get things going soon [/QUOTE]
            im having trouble doing the hls patch as well. method one has an error - no MD5 file found and zip signature verification failed
            method two - rename to update.zip and when you get to do the update it fails. if you rename it to update without the .zip it doesnt recognise it to give you the prompt to do an update. I also found it had to be on the external sd card, wouldnt do it on the internal sd
            any help please? im trying to get ftv add on working along with ontap tv
              Originally posted by natzen View Post
              i have problem ... impossible for me to install hls patch and deodex .... method 1 : failed and method 2 : invalid update package ...please help me
              did you find a way to do the update? i have the same problem
                Still running this fw since the release!! In combo with spmc.
                This is perfect!!!!
                  Hi Bob! I flashed this your rom 1.9 successfully. Thanks for your efforts to bring this rom to everyone at least to me! I highly appreciate for this!
                  Everything goes well, except following issues:
                  - loss bluetooth connection at the next reboot. I used the bluetooth combo mouse Riitek for years without issue. There is no issue with Minix stock rom as well. Can u check this ?
                  - On page 1 you shared the adb commands bug is fixed but I have no connection this with pc although X7 was driver installed with pc successfully. I want to mod some on SystemUI, lunar calendar for my end purpose.
                  Thanks for your advices in return.
                    Re: NEW - Minix Neo X7 - Finless 1.9 ROM
                    just reflashed, flashed also the deodexed zip succcessfully but adb commands are still no functioning
                      Started up my x7 just now!! Everything gone!! Damn!!!
                      Reflashed and up n running again. Anyone had this issue?
                        Please explain? What is gone exactly ?
                        Kar
                          Kar
                          All my apps are gone my launcher everthing gone. No ethernet anymore.
                          Spmc gone
                          Es file explorer app is there but says not installed. Watched yesterday evening couple of series with mx player.
                          Also mx player gone. Just erased i guess.
                          Reflashed 1.9 everything setup again.
                            Hummm, sounds like it might not have read the sdcard or the ext_sdcard was not inserted???
                            FLHT = Harley
                            HEMI = 2010 Dodge Challenger SRT
                            Cause I've been asked.
                              No ext sdcard in there....
                              Very strange but a clean reflash is nice i guess hahaha.
                              Good thing i dont have any picturew stored on it and so on...
                                Weird... It works just fine for me...
                                I guess that you have already enabled "Settings" - "Developer options" - "USB debugging".
                                The catch is that you have to enable "Settings" - "USB" - "Connect to PC" after every reboot.
                                If you also want to access your device from your computer as a Mass Storage device, you can go to "Settings" - "Storage", click on the three dots in the upper right corner, and select "USB computer connection" - "Mass Storage". After connecting the USB cable to your computer, two Removable Disks that correspond to the internal and external storage will appear, that seem to be inaccessible. To access these drives, you have to unhide the status bar, click on the USB symbol near the clock, select the "USB connected" option, and click on "Turn on USB storage".
