Robert Lemke | Cologne (Ger)
NEW - Minix Neo X7 - Finless 1.9 ROM
Re: NEW - Minix Neo X7 - Finless 1.9 ROM
Originally posted by robertlemke4 View Postif you speaking about the app at the Playstore (thats not the same torrent-dl-app like the PC-Version): yes. But its not good enought for me.
Its slow running at minix
Build.prop Samsung Spoof
I am currently testing the Finless ROM and I really like it so far, however, I accidentally deleted the build.prop file to spoof Samsung Nexus 10, is there any way someone could upload that file so I can add it back to the system folder, it would be much appreciated. Thanks!
status bar
Please tell me how to disable the auto hide the status bar? Untick the menu,but after a reboot the status bar disappears again and wish that he was always visible. Is there a solution to this issue? May need in the system files that correct? Please tell me,in the earlier thank for the help.
Originally posted by dimarik83 View PostPlease tell me how to disable the auto hide the status bar? Untick the menu,but after a reboot the status bar disappears again and wish that he was always visible. Is there a solution to this issue? May need in the system files that correct? Please tell me,in the earlier thank for the help.
Internal SD Card not mounting after upgrading to 1.9
Hi, just upgraded my X7 to finless 1.9, followed the directions to the letter and everything behaved as expected except now I cannot access the internal SD card. I notice others have had this issue but can't find a reply that indicates a solution. Do I just repeat the whole flashing procedure? Any help would be much appreciated.
Originally posted by Phantom007 View PostHi, just upgraded my X7 to finless 1.9, followed the directions to the letter and everything behaved as expected except now I cannot access the internal SD card. I notice others have had this issue but can't find a reply that indicates a solution. Do I just repeat the whole flashing procedure? Any help would be much appreciated.
Wipe data
Wipe cache
Reboot
If that don't work try re flashing. When the ROM boots for 1st time leave it for 5 mins so things settle down before playing around with the device....Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Originally posted by ant View PostUsing the reboot app > boot to recovery
Wipe data
Wipe cache
Reboot
Wipe data
Wipe cache
Reboot
Im in the process of installing as we speak
a flashed well, i just tried to install HLS streaming patch as per the readme file but it fails and says the was no MD5 file found or zip verification?
Also is there a way to spoof this as a Samsung S3 or similar? A Skygo app I want to us says its not compatible with this Nexus 10. Thanks
Sorry also for some reason Droidmote server installs but has an error about the licence checking for purchase which i havent had before - --- solved, was just a time setting which needed updatingLast edited by ryadre; 20 August 2014, 21:22.
did you find a solution for the weather info?
Originally posted by whoozy View PostThe weather widget in the Minix Metro Launcher is not able to catch weather information. Wifi and location services are enabled. I tried it with Ethernet turned on and off. In the original ROM it worked. Any idea?
[ATTACH=CONFIG]6609[/ATTACH]
did you find a solution for the weather info problem, i have the same issue
There are currently 1812 users online. 1 members and 1811 guests.
