NEW - Minix Neo X7 - Finless 1.9 ROM
Originally posted by fether View Postsame her sdcard unmounted
The SD card will then mount.
Power down the X7.
Turn power off.
Power on and reboot.
I had the same problem, but thought it was a Link2SD second partition 'issuse'.
SD card mounted now and reboot/power off shows SD card now still mounted.
I've seen my SD card become 'unmounted' in other builds too.
Minix 'quirk' maybe, haven't looked at any logcats.
its the internal sdcard wot is not mounted and the download folder says not mounted as well ???
any help appreciated
Power down the X7.
Turn power off.
Originally posted by Finless View PostI flashed this ROM so many times testing it, I cannot count! So you did something wrong.
First boot you should see the TWRP recovery. DO NOT, I repeat, DO NOT touch it! Wait and it will reboot on it's own. It was formatting /data /cache/ and internal sdcard in the background. If you messed with it and did not let it reboot, bad things will happen e.g. like sdcard wont be mounted in android because it did not get formatted.
Have tried on 3 different machines and successfully installed the drivers for 2 of the machines, but same outcome. Even used the existing drivers from my old 1.7 install on a 3rd PC.
Also, I assume there is no issue not having the userdata and backup boxes unchecked as this should not be required.
Firtsly thank you Finless for you hard work. So far everything works great. I have one questions:
1. Is this ROM 1080 Overlay or True 1080? I'm asking because if Minix is spoofed to Nexus then in XBMC screen resolution is 1080 if I change to Minix then resolution is 720. My TV is Full HD and I am concern if picture quality suffers.
Originally posted by hockeyfox View PostI do not see the TWRP screen. As soon as the rom is done flashing, it reboots and takes me directly to the red "freaktab.com A Finless Bob Rom" screen. And it freezes there. Using boot1080air and 1800 798 720 kernel. Will try flashing a different rom to see if the issue could be hardware related. I'm sure I will figure this out.
Also fyi the unchecked boxes are correct.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Originally posted by krasoft View PostVideo part with 1080p60 plays slower than the related sound. The connectivity is HDMI passthrough to Pioneer amplifier to Samsung TV. It plays 1080p60 videos slower on HDMI 1080p60 and 1080p30 though in sync using HDMI 1080p24. The latest official FWv10 plays such videos without this problem using HDMI 1080p60 passthrough.
Video is via HDMI to 24" IPS monitor (Dell U2410) and listening with Bluetooth headphones.
The original English track is close to perfect (no bluetooth audio advance) even the dub'd french track looks spot on.
Using MX Player Pro with HW+ acc. I manually set the Audio track to SW decoding too and it was still OK.
Checked the audio from the monitor (in via HDMI and out via 3.5mm) and that looked/sounded OK too.
Monitor and Minix box are set to 1080p60. I note the video I'm viewing is 1080p50.
So, set the Minix box to 1080p50, but still didn't notice any problem.
I have had to advance/retard audio on other older Android boxes, so I hear what you're saying, but I'm not seeing/hearing anything noticeable myself at this time using Finless v1.9
Yes I can make more OC'ed kernels if you all like.
Just tell me what you want.
I assumed most X7's would have no issue clocking to 1800 so I skipped 1704.
Originally posted by Finless View PostYes I can make more OC'ed kernels if you all like.
When I get home I will crank those out.
FYI CPU OC really doesnt get you as much as the DDR OC.
There are currently 1569 users online. 0 members and 1569 guests.
