HPH Android TV BOX RK3288
    Is anyone able to connect this to cheap Samsung 4K TV UE40HU6900? I would like to know if full color (4:4:4) is present, or only chroma subsampling (4:2:2).
      hello Tina, I was testing your home launcher. I noticed your launcher app for this box does not have a delete function after adding apps on the home page. You can add apps to the folders with the + sign. But their is no delete or - button to remove a app. Maybe a trash can option like most other home pages would work. I think it's a design bug.
        4k bluray
        so we might not need a 4k box..... we can now fill our shelves again with 4k bluray discs ?
          Hey userx,
          many thanks for the comment!
          Yes, it is just to delete the apps from the advanced setting right now,
          I will pass to our develop dept and ask them whether we could do the function which you mentioned.
          Thank you again,
          tina
            Hi TINA does Blu-ray Menu is supported and at which level ? Thanks
              Hey snipes,
              Rockchip just released the patch for the 3D blue ray
              we are testing it now
              btw, it will be much appreciated If anyone could be sharing the blueray source with us!
              thank you!
                Thanks TINA, That would be very cool if Bluray Menu is supported. That's the feature I was searching the most... Nobody seems to really supporting it FULLY ( NO BD LITE here ) that's a shame. I know XBMC can do it but it must be fully optimyzed for the device.
                  Thank you for the question!
                  So any updated news will let you know
                    Is a port of Ubuntu ROM from firefly board possible ?
                    Hi !
                    I am following this thread and the dev board also mentioned by Tina and made by the same company, whose website went live on Sept 1st : www.t-firefly.com.
                    Lots of files should be soon available at www.t-firefly.com/html/zh/download/ both for Android and Linux OS.
                    Mayble it can be possible to use Ubuntu and XMBC on the box using the rom files of the dev board ?
                    Dev board seems only available with 2gb RAM. Maybe it can be produced in 4gb as well. Board specs mention HDMI 2.0 60hz
                      "Does have ESD protection for the HDMI, so I don't like"?Protect the IC adequately from over-voltage stresses caused by ESD (electrostatic discharge) or CDE (cable discharge events).We have been talking about this here: http://www.freaktab.com/showthread.p...x-%28square%29
                      And here the most "curious":
                      "I was looking the board, touching the components with the fingers (without anti-static globes or similar) and after connect the board DID NOT WORK ANYMORE! (and even we know the board can be powered). It's curious, I was explaining what is the ESD and asking why just can find "the empty place" without anything there....
                      Examples:
                        Download latest Android KitKat 4.4.2 stock firmware for Nagrace HPH NT-V6 TV Box  from here , here or from here . You ca...
                            Why are you posting the same ROM twice, it has also been posted earlier in the thread by Tina.
                              Because he also clone the work that Javimetal had done
                              => http://www.freaktab.com/showthread.p...l=1#post224110
                              bad style wip7, bad style...
                              RK3288 Devices
                              - Overview BOX (LINK !)
                                I do not speak English, I write via google translator so the copy, what interests me,I'm interested in buying this box, here and I ask, what to pay,update came out 6 numbers, but we do not even HP Tina said, you can not do a bad support,,,in any case, I am sorry, I wanted clarity
