EDIT:hi,i see the profile of D33 an he is no longer active,somebody to recomend me for edit this kernnel? thanks
Pipo M9 Max RileyROM 2.6 KitKat
http://www.freak-tab.de/rrileypm/Pip...yROM_2.6.4.zip dead
btw I'm having trouble installing driver for m9 maxin win8.1. i used driver assistant , tick rockchip driver,untick adb driver, says driver installed but
when i go to device manager the "m9" has an exclamation mark saying driver is not installed.
furthermore I can't use rockchip batch tool/flasher/android tool it says one adb devices loaded but whhen i try to read flash info (to see how many cs 0 1 etc), popup says "match device type failed driver"Last edited by stillsomber; 17 March 2016, 11:02.
1nand (I opened and looked), upgraded to RR 2.64 from stock 4.1.1
on androitool in the zip in first post. advanced tab, read flash info, see that flash cs: 0 1 . others have tried, some succeeded, some failed.Then someone said dnkn said 0 1 and not 0 1 2 3 "might" mean it's ok to flash, I took the risk, now have KK, hope everything works, knock woodYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by kaglom View PostTry power up into flash mode,with esc and power at the same time when plug the usb in the computer
Hi to everybody.
Anyone can tell me if this rom works with internal 3G modem? I update my tablet with this rom, all works fine, but i´m not able to activate 3G.
can you help me?
thanks and regards!Last edited by pepelolo30; 12 November 2016, 10:49.
There are currently 3218 users online. 2 members and 3216 guests.
