Verstuurd van mijn ARN10bG3-Freaktab met Tapatalk
Arnova 10b G3 - ICS 4.0.4 AOSP with CWM and EXT4 - BETA1
Here it is just do install zip with cwm
Verstuurd van mijn ARN10bG3-Freaktab met Tapatalkif you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
Originally posted by snakekiller View PostI removed them too the deepsleep etc.
Good too here that this problem is solved
Have you downloaded my animation tweak.
Than you have a idea how it is in the final release
(I'm exhausted after a long day out with work so not going to attempt any changes tonight!)
I trying tomorrow too resize the wallpapers from the stock launcher.apk in ICS because of the glitch that some of you may know about when you choose a picture for a background it makes you crop it and then it doesn't scroll... .
Sow if it works then we have the full image on the screen
</form>
That would be great! I messed with that for a while yesterday, but gave up on it. I tried sending pix from my iphone over, but had to resize them down so much, they didnt look so good. You have to crop too much out of the picture. Huge resolution difference.
RandyRandy
The stock launcher wallpapers are scaled but if you take a wallpaper from the stock launcher its still sow big.
Like they are not scaled. But he wallpapers are now 1024x600 .
</form>
Don't know if any one cares for this but GTA3 runs on this rom its a little bit laggy but is playable I'm not to sure if chainfire 3d works on 10b g3 as I don't want to have to reinstall if it goes peat Tong and goes in to random boot loop or something
Sent from my ST15i using Xparent ICS Tapatalk 2
with a cwm backup no reinstall .
</form>
Well chainfire 3d has installed with no problems I'm just downloading data again for GTA3 cos I'm not to sure if it's a problem with the rom or if it's my tab but the internal SD keeps corrupting is anyone else having this issue? Oh and I noticed someone else was having issues with wifi my tab won't connect to wifi after coming out from sleep
Go into advanced settings under wifi and tell it to never turn off in sleep mode. You might also try an app called Wifi Fixer, I have to run it on some networks to maintain connection.
I can't figure out why...there is good signal and other devices including the 10G2 connect like clockwork, but the 10bG3 sometimes gets hung trying to obtain an IP address. When it gets hung, I have to reset the router for it to work. It never does this on iphone, ipad, G2, Wii, Xbox or any of my kid's android phones...just this 10bG3.
RandyRandy
Thank you randy I have just done that but my blooming internets has just popped so I will have to wait till morning to see if it makes a difference
Erm GTA3 seems to be a bit better with chainfire 3d on just need to play with settings to get the right combination I suppose
Snakekiller is there a place to submit bugs on this rom cos I think I have found a few
Regards
Jay
Sent from my XPERIA ST15i with ICS using Xparent ICS Tapatalk 2
Are there any audio tweaks we can try to make that little speaker sound any better?
RandyRandy
i removed deep sleep from build.prop
and a few other wifi tweaks.
mr weelson say its solved now the wifi.
but i can not confirm that because i havent not these problems.
why ? i don't now.
you must reply every bug or other tweak that's work or solves a problem.
so i can change the rom again , ok
</form>
i tried volume+ but not working .
the speaker is to shity.
you can use a other speaker thats fit in the case
</form>
Yes, I have tried volume+ too, but it mainly causes distortion, and it isn't much louder.
Audio sounds good with headphones though.
RandyRandy
There are currently 1538 users online. 1 members and 1537 guests.
