Arnova 10b G3 - ICS 4.0.4 AOSP with CWM and EXT4 - BETA1
    Ok randy for your bootanimation copy it to your pc.
    Open it (don't extract)
    Open the text file
    You see 1024 768 15
    It must be 1024 600 15.
    Save it.
    Copy now whole the bootanimation zip too system media again
    If you open it correct your zip file.
    And you restart your tablet than is the bootscreen correct on your screen
    Verstuurd van mijn Freaktab met Tapatalk
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
      Thanks. I'm at work till late tonite, I'll try it when I get home. (side job in the ER).
      I was just kidding about that anyway since I read a thread a while back that went off on a tangent about boot screens that seemed to go on forever. I figured it was kind of an inside joke. Sorry, Bob. I must have struck a nerve.
      Randy
      Randy
        can someone help me please i am installing the new beta rom but all im getting is black screen when i tell it to exit recovery on first boos from cwm after flashing
          Have you tried our old friend the paper clip?
            thanx for the reply bay i have done that and all its doing is putting it in to flash mode so rk tool recognises it
              gumbo - silly question but have you unplugged the cable before restarting the tab?
              If not i'd suggest just doing a reflash - erase idb & go again. Once flash has completed & you go into cwm you should make sure you've unplugged. Don't mean to teach anyone to suck eggs here - just want to make sure
                i didnt ill do that right now and report back give me 5 mins
                  lol no different it booted back to cwm this time i told it to repoot system and then black screen again
                    wtf??? Weird. Ok, in the rktools you did make sure all relevant check-boxes were checked prior to flashing, didn't you? Making sure the relevant paths were set to the img files? If needs be re-select all of the files locally rather than relying on the paths being set automatically & re-flash again.
                    Only thing I can think is that somehow the img didn't get in which is why its booting to black
                      Nope everything is checked off the way it should be in just extracted the whole file again in case it got corrupted ill re download it again in about 10 Mins just in case I have a dodgy download! If I can't get this to work is there anyway I can revert back to stock rom?
                      Sent from my ST15i using Xparent ICS Tapatalk 2
                        Yes - download the stock rom from Arnova's website. Don't use the rktools programme, you'll need rkbatchtool 1.4. You'll only have 1 update.img file. Set your rom in flash mode and once you've loaded the img file press 'restore' rather than 'update'. It will then format, put stock back on & you're set to go.
                          Make sure your download of Bob's ROM is good. Lately, I've had to download multiple times to get the whole thing.
                          Randy
                            thank you all im just going back to stock rom ill download bobs rom again in a min just to make sure
                              Snakekiller, that fix worked great. Thanks.
                              I'll never mention a boot automation screen ever again.
                              Randy
                              Randy
                                Ill now
                                </form>
