Finless 1.5b1 works very well with spmc "fork of xbmc" and xbmc 13.1 from oman. With finless 1.5b1 do install SDcard fix for kitkat and USBdebug (both free from googleplay).
NEW - Finless 1.8 for EM8 Square Box
Originally posted by Marton4 View Post... SDcard fix for kitkat and USBdebug ...
ROOT ACCESS IS REQUIRED. I've written a simple app which modifies KitKat devices to allow user-installed applications to write to the MicroSD card on devices with two storage locations. Background information on the underlying problem is...
USBdebug
https://play.google.com/store/apps/d...me.tennkia.apr ?RK3288 Devices
- Overview BOX (LINK !)
For the SDcard fix for Kitkat - NextApp SDfix: SDFix: KitKat Writable MicroSD
http://forum.xda-developers.com/showthread.php?t=2684188
For USBDebug: USB Debug
https://play.google.com/store/apps/details?id=me.tennkia.apr
Originally posted by Marton4 View PostFor the SDcard fix for Kitkat - NextApp SDfix: SDFix: KitKat Writable MicroSD
For USBDebug:
https://play.google.com/store/apps/d...nkia.apr&hl=nl
will this allow installing and running apps from an Sd card?
Originally posted by rlaursen View Postwill this allow installing and running apps from an Sd card?
With the fix (as far as I know not needed for newer Finless roms) I can read/write the SDcard. I use it for the cache for video-addons, apps-backup and for moving the Thumbnails map of SPMC/XBMC to the SDcard1 by using the advancedsettings.xml within /userdata map with:
<advancedsettings>
<pathsubstitution>
<substitute>
<from>special://profile/Thumbnails/</from>
<to>/storage/external_storage/sdcard1/spmc_thumbnails/</to>
</substitute>
</pathsubstitution>
</advancedsettings>
Originally posted by Marton4 View PostThat I haven't tried yet. In this thread you can read if it works with Link2SD app:
<advancedsettings>
<pathsubstitution>
<substitute>
</substitute>
</pathsubstitution>
</advancedsettings>
Guest
can someone upload the file in the root of sd-card (internal memory) of 1.8 ROMs called:
recovery.img
to:
for me please?
Thanks.Last edited by Guest; 07 August 2014, 06:28.
Originally posted by handroid View PostThat's an interesting solution. Never knew you could do this using advanced settings. Can this be used for setting your external SDcard as cache forXBMCtorrent? Would solve the dreaded damage to your flash using this add-on.
Guest
Originally posted by washere View Postcan someone upload the file in the root of sd-card (internal memory) of 1.8 ROMs called:
recovery.img
to:
for me please?
Thanks.
hi! visual artifacts when playing this file https://yadi.sk/i/qjd_WiDUZM5Uf (freeze and flicker; 7.1 sound -> stereo) and https://yadi.sk/i/ob9RNMFmZKbb4 (like interlaced)
Originally posted by almirus View Posthi! visual artifacts when playing this file https://yadi.sk/i/qjd_WiDUZM5Uf (freeze and flicker; 7.1 sound -> stereo) and https://yadi.sk/i/ob9RNMFmZKbb4 (like interlaced)
There are currently 2158 users online. 1 members and 2157 guests.
