NEW - Finless 1.8 for EM8 Square Box
    Originally posted by snelsy View Post
    I bought my M8 from Acemax and it came in an identical box but i have been able to install any rom recommended.I am currently running Bob's 1.8 rom with oman xbmc and all is running smoothly.I haven't opened the box up but i asume it is not a clone as things just work when i try them.
    As you have mentioned External parts and Packing Identical thats why I've asked to joperiera who is the seller cos its a different PCB ...
    Actually we are not even sure whats going on But Many seller Gave me Price and said its Original M8!
    I've asked what you mean by Original? is there a Clone M8? the answer was YES!
      Yes to both.
      The seller is a generic **** one (named "terrific0123").
      Is this a known PCB layout?
      ps - by the way, attached a picture from the back
ID:	434300Click image for larger version
ID:	434301Click image for larger version
Name:	M8 (back).jpg
      120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
      M8 TV Box Codesnake's OpenElec 6.0.3
      Tronsmart MXIII+ (v108L1) + KODI 16.1 (Jarvis)
        Originally posted by jopereira View Post
        Yes to both.
        [ATTACH=CONFIG]7334[/ATTACH][ATTACH=CONFIG]7335[/ATTACH][ATTACH=CONFIG]7336[/ATTACH]
        Parts are same but Layout and manufacturer name is different ....
        So Do you have any Problem with this device? If you ever tried M8 Square Roms from this forum and haven't got any problem means Finless Rom should work for you...
          Re: NEW - Finless 1.8 for EM8 Square Box
          Here is mine..pcb...
          Will finless 1.8 work with my box..i need to make sure first b4 flashing...anybody...here got the same.. Its says.thanks
          M9&M8 V 0.92
          2014/03/12
            M9&M8 V 0.92
            2014/03/12
            That is the Official PCB Mate
              Thanks mate..so it means im fine flashing finless 1.8?
                I have just received it today, not even turn it on... but already open it and took a million pictures of it!
                I guess I'll have to take the risk...
                  YES.
                    Don't be Negative At Least all parts are same...
                    Before Flasing a new ROM check the FW version etc. please
                    Good Luck
                      Thanks..a lot..
                      Success flashing finless 1.8..
                      ..time for testing...is oman xbmc better for finless ..or just the default one...thanks..???
                      Thank you guys here..!!
                        Thanks..a lot..
                        do Oman's
                        advancedsetttings.xml
                          hi washere can you please reply my message on page 4 since you're the expert?
                            Originally posted by ftv View Post
                            Hi all.
                            Thanks to Bob for his hard work!!!
                            Just to confirm there's still issues with this 1.8 (remote control issues and interlaced video?)
                            Does the interlaced video issue only happen when using 1080i? I don't want to go through the hassle of updating if 1.7 is better at the moment.
                            I'm hoping that these issues are fixed as I get a lot of xbmc crashes on 1.7 and someone mentioned less crashes on 1.8!
                            And also just to verify if i go into preinstall folder of this ZIP and swap out the stock XBMC with my personal customized XBMC it will preinstall while flashing?! If yes you're a life saver haha!
                            Thanks in advance for your reply!
                            I'm no expert, I don't do any O/S programming or android but I can create AI systems if I could be bothered to be interested in computers again, I'm just an android user.
                            * remote control issues I have not had, I would advise the person who had it to reinstall
                            * interlaced video: not yet, anyone gets it post a pic please if using Oman xbmc + asdvancedsettings.xml as I said many times, I doubt it. I now have all 3 hardware accelerators in xbmc enabled & no problems
                            * as for hassle: try to learn titanium, free version just asks to reinstall apps 1-by-1, copy folder to sd-card as it deletes it in factory reset in recovery, then reinstall
                            Titanium Backup (& restore) app is very easy:
                            menu button: Batch actions: backup apps
                            menu button: Batch actions: restore apps
                            IF the backed-up folder in root of box memory is not copied to SD-CARD: WILL BE DELETED IN FLASHING NEW ROM !
                            Copy back to
                            box memory after flashing new ROM, to restore.
                            * Just flash 1.8, uninstall included xbmc, install Oman xbmc + asdvancedsettings.xml in my thread:
                            * also restoring xbmc addons takes a few moments to new ROM IF the addons folder is SAVED PROPERLY on the old 1.7 ROM onto SD-CARD for restoring
                            * Linux by Stane is no O/S just xbmc but I need android O/S & apps, not just xbmc.
                            I have various pads & wireless keyboards & another remote + M8 remote which is still useful to interact with M8.
                            To setup your M8 use a $3 wireless PC mouse, much faster.
                            Anyone with M8 wanting android: has to install this 1.8, much superior than any ROM
                              Thanks washere!
                              What version of XBMC does Oman use? I've rather enjoyed using stock 13.1 gotham and customizing the addons myself.
                              If I use Omans can I copy and paste my org.xbmc folder so I get all my customizations to automatically load?
                              I want the best experience though so your guidance would be appreciated!
                                Thanks washere!
                                yes it's gotham
                                use Total Commander app to copy that folder fast before it's wiped in flashing:
                                click on folder icon (not name) to select
                                click second icon at bottom with arrow to copy to 2nd pane on actual sd-card2
                                copy back after flashing
                                set settings
                                who doesn't but life's a b!tch then we die.
                                going out now, good luck
