JustMe
NEW - Finless 1.8 for EM8 Square Box
Well done Bob, same issue with interlace
JustMeBugs are Sons of Glitches!
JustMe
CEC Control Issue with ROM
i have a Sony TV and though when i turn HDMI CEC Control on everything works as normal even turning the TV off turns off the AMLogic M8 turning it back on does not and i have to unplug power and re-insert, resolved for now by turning off the feature on my tv of turning off the box when i turn off the TV but it would be nice to have it working.
Otherwise love this Clean Stock Feel Thumbs Up.
Advancedsettings.xml
Hi guys I know this is not a rom issue as it also occurred on v1.7 but whenever I transfer the advanced setting into the default directory I cannot watch any streams whether they reside on the LAN or Internet.
The video stutters and plays as if your pressing the forward key on your remote. Streams from the internet don't play at all. I have got a fair bit experience with XML files creating, any ideas what can be possibly wrong? I've used the same file for my mates android box not a amlogic chip though and that works fine.
thanks in advance
Originally posted by userofthenet View PostDid anyone tried a different XBMC (like Oman) to see if that would fix the interlaced video bug.?
I was really happy with this latest ace 22-07 FW till I notice that bloody interlaced video bug
Originally posted by dadog2t7 View PostHave you used this rom yourself man?
I have its great easy to install and get going Truly Rooted already installed Root Explorer, Ad Away runs Plex like a dream, my only concern is the Launcher not a fan to be honest but that aint Finless's fault there doesn't seem to be a solid TV Launcher out there. Hopefully Google's Android TV will assist Launcher wise.
Anyone's Experience is this likely to get an Android L Firmware update or do they stay on the current release i.e. no update to 4.4.3 or 4.4.4??
Re: NEW - Finless 1.8 for EM8 Square Box
Originally posted by iTzSnicholls View PostI have its great easy to install and get going Truly Rooted already installed Root Explorer, Ad Away runs Plex like a dream, my only concern is the Launcher not a fan to be honest but that aint Finless's fault there doesn't seem to be a solid TV Launcher out there. Hopefully Google's Android TV will assist Launcher wise.
Sent from my Minix Neo X8-H using Tapatalk.
There are currently 1907 users online. 1 members and 1906 guests.
