NEW - Finless 1.8 for EM8 Square Box
Guest
Originally posted by Iru786 View PostHi Guys, Can you please advise if you still need to use SoundAbout app with this? Coz 1.8b works for me without it. Thanks
Hi all.
Thanks to Bob for his hard work!!!
Just to confirm there's still issues with this 1.8 (remote control issues and interlaced video?)
Does the interlaced video issue only happen when using 1080i? I don't want to go through the hassle of updating if 1.7 is better at the moment.
I'm hoping that these issues are fixed as I get a lot of xbmc crashes on 1.7 and someone mentioned less crashes on 1.8!
And also just to verify if i go into preinstall folder of this ZIP and swap out the stock XBMC with my personal customized XBMC it will preinstall while flashing?! If yes you're a life saver haha!
Thanks in advance for your reply!
I had 100% less crashes on the firmware and XMBC that came with my box.
Well, when i say crashes, i mean within XBMC, so it may not be ROM related.
Old ROM and XBMC hardly ever crashed, and definitely never Red Screened.
But as far as a ROM goes, this 1.8 seems very clean, it makes the hardware work much better.
Which is its job. XBMC, well thats another story altogether.
Originally posted by jopereira View PostMy M8 box has this PCB.
Should it be safe to install this firmware?
Thanks in advance.
[ATTACH=CONFIG]7332[/ATTACH]
JP,
Lisbon, PORTUGAL
look more like mxIII just by judging the ap6330 chip on top of the board it also looks like square m8
maybe some else can comment
JustMeBugs are Sons of Glitches!
JustMe
Thanks in advance.
JP,
Lisbon, PORTUGAL
Our Boards are V0.92 not from that manufacturer Wifi chip is on the other side of the board ,little differentpcb layout...
Guest
I never had red screen of death or similar crashes, see my sticky thread:
Guide to Flashing ROMs & installing xbmc: on how to
# Uninstall included xbmc
# Install Oman xbmc
# Add xml file advancedsettings as instructed there
Photos of M8 circuit board:
Originally posted by washere View Post
Originally posted by jopereira View PostThis is an external view of my M8 and its box.
Hope this help to clarify.
Does it has Samsung Nand chips? and wifi chip is it 6330?
can I ask who is the seller of this box please?
Originally posted by TMx View PostExternal Parts are same but The box you got has a different PCB ...Possibly a Clone...
There are currently 2254 users online. 0 members and 2254 guests.
