NEW - Finless 1.8 for EM8 Square Box
Re: NEW - Finless 1.8 for EM8 Square Box
Originally posted by iTzSnicholls View PostNo i manually installed from Google Play Store had no issues at all even with 1080P content.
I just downloaded rom plan on installing next day or two when I have some time
Sent from my Minix Neo X8-H using Tapatalk.
Guest
Went into recovery with hard reset button
Factory reset twice
Installed ROM
booted up
rebooted into recovery again and flashed cpu-fix 1008
Restored hundreds of my apps in a jiffy with titanium
Restored my launcher's settings
uninstalled the hopeless included xbmc
installed my previous 2 xbmc apps
restored my previous xbmc addons/settings/etc in a jiffy
all took about 30 minutes
checked 2 movies in 2 xbmc apps: streams hd fine
had to reinstall play store apk as before (white screen again, couldn't wait 10 minutes )
If you have no sound:
Get background mp3 or radio or audio running to check when fixed then:
toggle various hdmi settings in app SettingsMbox till works
Only needs doing once
set my display to 1080P @ 60Hz: make sure your TV can handle whatever you set
Runs super smooth & super fast & cool, best ROM yet, will test on.
Thanks Bob.Last edited by Guest; 30 July 2014, 19:51.
Can ask whether you transfererd the advancedxml file, if you have then that the same problem I have.
If you remove it it will run propoerly but you dont have the tweak
Originally posted by dadog2t7 View PostInstalled the rom and it's really slow, xbmc wouldn't start so I installed beyond xbmc and it plays a video for 2 secs and then crashes. Anyone know what's wrong??
Finless 1.8 for M8 Amlogic S802
hi bob
i have tested your finless 1.8 rom for square box but on my M8 Amlogic S802 its working very nice.
the chiness firmware are all the same and no fixing they are bad.
good to have bob who make very nice roms look nice and have a lot of fixes.
I also want to say i have tested all the roms from:ACEMAX M8 allminipc-ugoos-m8-amlogic-s802 and enybox M8 and EM8 Tomato Square box all working with M8 Amlogic S802.
I dont understand why you say always finless 1.8 rom for square box its working also with M8 Amlogic S802.
thanks
wahran
Smooth Running Rom
Hi Bob would like to say thank you for a great Rom (was using beta)
If you don't mind me asking. is there a way that I could edit the rom and stick my own custom xbmc.apk in the rom so when I re-flash it is already there?.
Secondly this is an issue don't know if anyone else is having it but the remote that come with boxes on this rom all the buttons are doing the incorrect things within xbmc And certain menu's In Android. like return turns volume down in xbmc and in settings on the box. home turn's volume up thought it was the remote file in xbmc until it did it on android settings also. Any Ideas?
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by Apostle View PostHi Bob would like to say thank you for a great Rom (was using beta)
As for your own XBMC. XBMC gets pre-installed on first boot. just remove the XBMC in /system/preinstall and copy in your own. Then do a factory reset and next boot your XBMC will be installed.
Originally posted by tampametal View PostWhat xbmc is on rom latest from website?
JustMe
Originally posted by tampametal View PostWhat's known to work best on previous rom releases for xbmc?
try omans posted in teh beelink section or try acemax's which was posted by tmz
mate not being rude what works for one person may not work for other person get in there and do some flashing and testing its all trial and error and what works best for you
JustMe
There are currently 4859 users online. 0 members and 4859 guests.
