NEW - Finless 1.8 for EM8 Square Box
    Finless 1.8 for EM8 Square Box still xbmc freeze or crash
    hi
    i triwd the new finless 1.8 with my M8 Amlogic S802 its fine but problem with xbmc freeze or crash its the same with all firmware i tried.
    please help.
    thanks bob
    wahran
      Originally posted by wahran View Post
      hi
      please help.
      thanks bob
      wahran
      Hi Wahran
      That is not possible you either got a faulty box or a Clone cos There is a rumour about Clone M8 boxes...
      Could you please open the case carefully and share the picture of your M8 PCB (motherboard) ?
        Big thank you to Bob
        Got it downloaded. Your instructions in ReadMe are a lot easier than the Guide to Flashing ROMs that is on here.
        The boot time took forever compared to my last ROM that came with the unit.
        Welcome screen is very nice.
        Having issues with tronsmart remote and standard remote.
        Tronsmart with adding the "."
        Generally the UI is slower than the one that came with my box.
        Maybe it will improve with time?
          Great rom
          Thanks a bunch Bob. So far no problems whatsoever. This is a masterpiece. Donation on its way.
          Will post some test results later
            The only minor problem i had was google play store kept loading ,i cleared it's cache and disabled then enabled the app and now it loads almost instantaneuosly.
              5 to 10 minutes after booting, the Play Store white-screen of load-loop usually doesn't happen.
                Hello everyone, I am new to this forum and I have a question. If I use this ROM with xbmc Oman have I no longer suffer from frame skips / drops. Maybe you have more tips for a solution on frame skip / drops. I also have the M8 android TV box. Thanks for your help.
                Greeting Comity.
                  M8 PCB of M8 Amlogic S802
                  hi
                  how to open thr case of M8 PCB (motherboard) i have take off the four screw of the case but i cant open it
                  thanks
                  wahran
                    hi
                    thanks
                    wahran
                    there are few plastic clips, use your nails gently around front LED area to take it a part
                      Originally posted by iTzSnicholls View Post
                      also any chance on CWM or TWRP being compiled for the M8 Boxes?
                      Hey, I'm dying for a CWM or TWRP backup solution as well. These boxes are taking me forever to customize! Anyone have any clue as to any developments on this?
                      I was checking on androidgadget, androidpc.es, and freaktab of course....no luck yet.
                      For us resellers, this comes in REALLY handy!
                      Oh! And great work Bob (Finless) - your work is truly amazing - thank you so much for your time and efforts!
                        Originally posted by TMx View Post
                        Thanks for the info Bob...
                        Guys could you please Check if you are gonna have interlaced picture in XBMC time to time cos I do have few times barely visible interlaced Picture like this one but not this bad (found this from net) restarting video or fwd/rewind solves the problem ;
                        i too started noticing this on the stock 07-22-2014 rom myself
                          I've reported this to Acemax and they've confirmed they are gonna check whats wrong ...Hopefully they'll fix it by the next fw release.
                            Occasional clicks and pops in audio when 5.1 or above
                            But, video play back vastly improved, nice clean ROM, plenty of options.
                              Mine just started doing this
                                remote.conf
                                I did not test the remote and kept the remote.conf that came with it. So if it is messed up it should be on the stock ROM too. All you should need is the remote.conf from 1.7 ROM.
                                As for your own XBMC. XBMC gets pre-installed on first boot. just remove the XBMC in /system/preinstall and copy in your own. Then do a factory reset and next boot your XBMC will be installed.
                                When trying to edit or replace remite. Conf it won't allow it. Would I have to edit Rom with android kitchen? Do it that way?
