Thank you
NEW - Finless 1.8 for EM8 Square Box
Hi. I did mistake with USB port. I have an TV Box M8. When i flashed this rom it updated and then re-booted however it only loads the screen which says a finless bob rom V1.8. It doesn't go past this screen. The reset button doesn't work too. I think the tv box stay in FLASH TOOL mode .Do you have solution to this problem ? How can I do flash this rom again?
Thank you
hi, i hope i have not overseen a discussion about my issue:
i downloaded the finless rom and installed it without errors. i rebooted the system but the box is stuck at the boot screen (finless boot screen).
i can force him to start the recovery - so the box is not bricked (my box was bricked. i solved it and had different roms running without a problem).
what can i do?
thx
joel
Originally posted by joel75 View Posthi, i hope i have not overseen a discussion about my issue:
what can i do?
thx
joel
in the system recovery i see: "KOT49H.20150515 test-keys"
i tried reinstalling the rom with several times factory reset. no changes. stuck in boot screen...
Originally posted by Finless View PostOK folks.... a lot of work went into this ROM yet again! Another 2 days
Had to fix NEW bugs they put in this new ROM.
This is made from the latest Acemax 7/22 ROM that just came out.
I have done things to this ROM that is not in any other ROMs I have made so far for any S802 box, so your getting my best right now.
If you like this ROM and the work I put into it, consider a donation please.
Not to beg but again lots of work for you ENY M8 users.
________________________________________________
Features and release notes for my 1.8 ROM:
1) Properly rooted using SuperSU. What does properly mean?
Android 4.4.2 requires SU to be running as a daemon now. There are many ways to run this as a daemon.
Most roots so far are using a install-recovery.sh script or if init.d is enabled, a init.d script.
This means you could lose root if messing with these scripts which some rooted apps do!
What I have done is started the daemon in init.rc thus eliminating the need for boot scripts!
This took me a while to learn to do! Enjoy a BETTER ROOT!
2) Updated Google framework and Play Store core files. The ones in the stock ROM were out of date.
On first boot NOTHING will need to be updated once you logon to Google Play.
That is as of this date.
3) Debloated of junk APPs and Google Apps you can get from Google Play.
There was quite a few useless hidden apps in this KitKat release! Some of them did not even work.
I like a CLEAN ROM that you the user can setup the way you want.
Having APPs in /system leaves that junk in there forever (unless you delete them by hand with a root explorer).
4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
5) I fixed the AOSP Launcher for several things:
Removed the google search bar by request.
Added more than one screen for scrolling.
Updated the dock icons to things more useful.
Apps installed with Google Play will automatically be added to the home screen.
I think you will like this launcher better
6) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device (Nexus 10) that will show almost any APP as compatible.
This should also allow Netflix HD but I have not tested it.
Your device will show up in google play as Nexus 10 device not a M8! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a M8.
7) Fixed a new recovery issue! What they did this time was pretty stupid if you ask me.
They modified recovery to install XBMC from a TAR file located in /system/
What this causes is anytime you use recovery to install a patch (like my CPU patcher) it re-installs XBMC.
Why they did this is beyond me! Just stick with the preinstall script since it works!
So I reverted back to that. Anything in /system/preinstall will get installed on first boot and ONLY first boot.
If you do a factory reset, it will get re-installed again.
Right now the modified XBMC from the 7/22 ROM is in that.
If you don't want this XBMC to be installed after a factory reset, simply delete anything in /system/preinstall.
8) Xbox and PS3 KO modules are now installed on boot.
This should make wired PS3 and Xbox controllers work.
I do not have one and cannot test so let me know.
BT controllers still don't work due to AML drivers.
9) 1080 24hz support!!!! Yep, it's there now in display settings!
Basically the setting 1080i 50hz was replaced with 1080P 24hz.
Special thanks to Hardware GURU for coming up with this on the Neo X8.
He told me what he did and then I implemented in the M8 ROM.
10) Added bonus! CPU fixer patches!
In this ZIP is a CPU_fixer folder. These zips can be used to adjust your minimum CPU frequency and Governor. See the README.txt in that folder for an explanation and how to install them.
11) 720P patcher! This is for people with 720P only TVs. If you have a 1080P TV I suggest you not use this.
The stock ROM desktop is locked to 1080 resolution even if you set to 720P.
Yes the output to the TV is 720P but the desktop resolution is locked to 1080.
This throws off some media player APPs because they think you are in 1920x1080 mode and your not.
Videos then play weird with a small box skewed over. This is noticeable in XBMC.
SEE THE README in the patch folder for more information! A TON more information about this and how to install.
Also in that folder I give you CPU fixer patches that work with the 720P patch.
DO NOT interchange CPU fixer patches between 1080 and the 720P patch!!! You have been warned.
12) Boot logo AML badge now displays 1080 or 720 depending on what resolution you are booting in.
This is helpful to know exactly what mode you are switched to.
13) I added a reboot APP that will allow optional reboot options like reboot to recovery for easier updates.
14) Carrier spoofs for better APP compatibility.
15) The usual tweaks I do for better performance e.g. TCP buffers sizes, etc etc.
16) Did some "theme'ing". Hope you like it!
__________________________________________________ _____
READ THE README.TXT in the ZIP download for instructions!
The ZIP download has the ROM and other goodies inside.
DO NOT simply put this ZIP download on SDcard and expect it to work!!!
OK so here is the download!
ROM -> EM8 Tomato Square Box - Finless ROM 1.8 (447 megs)
Enjoy,
this rom install usbrecovery mod and more dead mxiii... What should I do? model:mxiii 2gb/8gb mother board name:MXIII V2_0 20150526
1-usb don't work
2-av port push the button in do not work (recovery)
3- SD recovery dont work
4-otg dont work usb Can not find driver pc
only the red light is on What should I do? please help me !!!! not turn blue light
**** I'm sorry for my bad english
Thank you
https://www.google.com.tr/search?q=m...wOFpHwgB0pM%3ALast edited by anne12; 10 December 2015, 07:52.
There are currently 2046 users online. 0 members and 2046 guests.
