NEW - Finless 1.8 for EM8 Square Box
Guest
Originally posted by warlock09 View PostMaybe ,not sure you can try his CPU patcher that came along with the firmware it might solve your problem..but i dont know which one to use as i dont use my box(M8) for gaming..
Ill try setting the Governor to Interactive when gaming on the box to see if it fixes it.
Originally posted by crowruin View PostI have a big issue with this rom the issue is that my M8 Overheats when playing games like Asphalt 8 or Dungeon Quest.
it overheats and freezes my whole box...RK3288 Devices
- Overview BOX (LINK !)
Guest
Originally posted by no_spam_for_me View PostAre you sure it's because of overheating and not because of a bad PSU?
its hot to the touch too but its only when im gaming im guessing its the games since they are really cpu intensive.
but other apps like XBMC work perfectly fine no overheating at all.
I also have a PSP Emulator I can play that for hours and the box doesn't freeze and it isn't as hot as when im playing Asphalt 8 and Dungeon Quest thats weird.
You can also try to use 'StabilityTest (ROOT optional)'
to check if it only happen at CPU (Classic Stability Test) or at CPU+GPU (CPU+GPU Stability Test) ...RK3288 Devices
Guest
Originally posted by no_spam_for_me View PostYou can also try to use 'StabilityTest (ROOT optional)'
Until the boxes freezes up? or is it a set amount of time?
Edit: no crashes yetLast edited by Guest; 22 December 2014, 19:11.
Edit: no crashes yetRK3288 Devices
Guest
Originally posted by no_spam_for_me View PostI would say, use the same time as you get the freeze at the game(s), but 1:44 hour seems to be enough to exclude overheating (or is it much cooler at touch-test?)...
but after I played some games on my PSP emulator while the box was hot and it didn't freeze.
its weird I can play psp emulator games all i want but games like Asphalt 8 freeze after an hour or 2.
Stuck at splashscreen
Installed om my box, when I booted I get 1080p splash screen, waited 5 mins, but didn't boot, so as in a hurry put old ROM back on. Does this take a long time to boot after install or something? or am I not going to be able to run this build. think I have a clone. Is there anything else I can try to get it going?
Cheers
Every time I try to boot into recovery I get this screen. I can't flash anything nor control the selection on screen with the remote, keyboard or mouse. Anyone seen this before? I read through the whole thread and nobody mentions this at all.
Thanks!
Edit: I am currently on finless 1.6 trying to upgrade to 1.8.
Re: NEW - Finless 1.8 for EM8 Square Box
Originally posted by Finless View PostMy 1.7 ROM is still here and you can download it and flash it if you need to go back.
Backing up a AML ROM requires knowing a little linux and using ADB.
sent from my Wicked 4.3 hybrid
problem of connecting the monitor
Hello. After installing Finless 1.8 on M8 Amlogic S802 the device stopped issuing hdmi video signal to a monitor that has a native resolution 1280 x 1024. When connecting another monitor that has a native resolution 1920 x 1080 - everything is fine. What to do, please tell me.
P.S.
LifeForce changed firmware and it worked. And worked faster than Finless 1.8. We assume this lab testing firmware: Finlessware in a bucket.
Physical reset button
Originally posted by cK3n View PostProbably a stupid question but where is the phisical reset button?. Put your box in downloadmode: disconnect the powercord, press and hold the reset button and reconnect the power. Wait for about 10 seconds to release the reset button.
There are currently 2136 users online. 0 members and 2136 guests.
