NEW - Finless 1.8 for EM8 Square Box
failed flash
Tried to flash this rom on my new M8 box (Model Best M8) Copied the files from the archive to an sd card and put it in the box. Did the reset and power but it went back to normal load. Realised there is no recovery file in the archive. Downloaded a recovery file from a stock m8 archive and copied that to the sd card. Tried the reset again and it shows the android and a bar at the bottom loading the update. It only gets a quarter of the way across the screen and then stops.
Anyone know what Im doing wrong? Even tried using the update tool in the installed rom, but same issue. Tried a different Rom, and same thing again. Only gets a quarter of the way..
xpad.ko
Originally posted by Finless View PostOK folks.... a lot of work went into this ROM yet again! Another 2 days
Had to fix NEW bugs they put in this new ROM........
8) Xbox and PS3 KO modules are now installed on boot.
This should make wired PS3 and Xbox controllers work.
I do not have one and cannot test so let me know.
BT controllers still don't work due to AML drivers.
Enjoy,
... anybody have this problem? have solution?
nice rom.. tks
Bobs 1.8
I am new to this forum and have to say I am glad I found it. I have tried the three major roms stanes, JM and Bobs. First stanes does work but for my M8 v.092 it is buggy. I have tried Just mes but only version 1.0 will load on my M8 version 1.1 loads but is buggy . JM's version 1.2 will not load and I have tried all methods stated on his thread and I get the android error ... this is strange as version 1.0 loads. But moving on I have tried Fins 1.8 and for my box this is the best. I am still on XBMC 13.1 and seem to have some issues with 13.2 ( I removed 13.1 on at onset and installed stanes apk). I reverted back to 13.1 and it runs really well. I would like to put on 13.2 back what version do you fellas recommend. I hope Bob has a version 1.9 with an embedded 13.2. Just my two cents. I would like to try JMs because of the posted speeds and stated stability issues but like some of you it just will not load. So 1.8 BOb is the one for me.
So I finally stepped into these devices (all my prior experience is with the CS968, RK3188 based device). I am saddened to see theres no real good stock roms, cause now I have to choose between competing custom roms, which is always a pain. I know Finless is a gret dev so I've chosen his for now. Got 29k Antutu score BUT only after having the box crash 3 times during the test. My box is a high quality build from ****** stamped V0.92, though with Nanya ram chips instead of Samsung (I sincerely doubt it matters but it would be interesting to compare Antutu ram score numbers).
I am curious to try JustMe's, even though apparently it still has some kinks to work out.
Any suggestions?
There are currently 1840 users online. 0 members and 1840 guests.
