iFive Mini 3GS RileyROM 1.5
I've uploaded v1.5.1, which is the same ROM, but packaged with the same flash tool I put into v1.4.Randy
Originally posted by rrileypm View PostI've uploaded v1.5.1, which is the same ROM, but packaged with the same flash tool I put into v1.4.
Just a quick question, If I want to modify the internal storage (increase it to 8GB for apps), do I just use the EBR tool and create two EBR files and replace it with the ones you have under your ROM , then flash the tablet?
If you notice there is only an EBR1 file with this ROM. This is because in the last two versions, the user app space has been combined with the internal SD space. There is no need to change anything in the EBR file because you already have maximum space for your apps.Randy
I just posted a lengthy set of instructions over on the 1.4 thread, but it also pertains to this version:
Randy
One thing different about v1.5 is that if you already have v1.4 installed on your tablet, you can use the default "download only" mode to flash this ROM...and you don't necessarily have to wipe/factory reset your tablet. This is only if you are going from an earlier firmware version that had the old parameter settings for user app space.Randy
Originally posted by Ced91 View PostHi everibody,
It's ok now to install 1.5 when replacing the RILEY ROM Folder into the 1.4.
But I don't know why but I have in my WIFI SSID list an "NVRAM WARNING: Err = 0x10" message in place of a SSID AP.
Can someone help me to restore a good NVRAM?
And restore a good IMEI number.
Regards,
But I didn't find any solution to recreate a nvram.bin with my EMEI number.
I test to give a phone call but no ring... and when calling the tablet from another phone operator indicate not possible to join the phone.
PIN code and operator network authentication ok, 3G ok.
I think that the actual IMEI number is blacklisted by the operator.
Someone can help me?
Regards,
Randy
Thanks, but there is no menu call "Connectivity/CDS Information".
I only have Bluetooth, FM Receiver, WIFI, WIFI CTIA, WIFI Display.
So I can't go to the end of the process.
Regards,
Let me get my tablet out and look at it.
Stay tuned.Randy
There are currently 3553 users online. 1 members and 3552 guests.
